VCDS German 23.11.0 Update
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post11-02-2024, 11:44    Subject: VCDS German 23.11.0 Update Quote
Dear customers,
VCDS 23.11.0 Update
The new German VCDS version 23.11.0 with an updated data version 20240123 is now available.
In your customer account under
you will find updated installation packages for your VCDS diagnostic software to download.
Changes:
- New feature: Support for new/upcoming models
- Improvement: DoIP support revised
- Improvement: Basic settings for ASAM/UDS (parameter passing) revised
- Improvement: Activation/deactivation of transport mode (MJ 2020+) revised.eitet
- Improvement: Revision of historical data retrieval for current models.
- Improvement: Revision of engine group control unit data display (e.g., V10 TDI).
- Improvement: Revision of translations and error messages.
- Improvement: LCode coding plugin/assistant updated.
- Improvement: Configuration and update program (VCIConfig) for HEX-NET & HEX-V2 revised.
- Control unit documentation (label files and ODX/ASAM data) expanded/updated.
Is the car to be diagnosed not an Audi, Cupra, Seat, Skoda, or VW?
Perfect addition for other vehicle brands:
Multi-brand OBD diagnostic tool.
Questions about using VCDS / OBD, specific procedures, or automotive engineering?
Diesel mechanic community
Rainer Kaufmann - Kaufmann Automotive GmbH
www.dieselschrauber.org - www.canhack.de - www.kaufmann-automotive.ch
CAN Interface
CAN-Bus Interface RKS+CAN Multi-brand
OBD diagnostic tool
Mehrmarken OBD-Diagnosegerät
KDataScope
VCDS Log Viewer
https://shop.dieselschrauber.org/en/account.php{MARKER}{MARKER}finden
Post16-02-2024, 10:47    Subject: VCDS German 23.11.0 Update Quote
Update to data as of 20240207, which includes, among other things. Resolved issues with service delays.
Post23-02-2024, 13:13    Subject: VCDS German 23.11.0 Update Quote
All installation programs have been updated to 20240219, which also includes the latest version of LCode. The main reason, however, is the switch to a new code signing certificate.
Important: The main version of VCDS remains the same during data updates (in this case, 23.11.0); you can see the data version in the "About..." screen of VCDS. icon_idea.gif
Post06-03-2024, 14:46    Subject: VCDS German 23.11.0 Update Quote
20240306 is now online and includes several corrections related to Audi A6/Q7 (4F/4L) instrument cluster labels, which are particularly noticeable when attempting service resets. There is still a variant (Pre-Facelift, SW 0900) that is temporarily not covered, which is rare but exists, and will be added back as soon as a corresponding fix is integrated.
The VCDS download is, as always, available in your customer account.
Post22-03-2024, 13:22    Subject: VCDS German 23.11.0 Update Quote
VCDS data version 20240322 is now online and includes the usual additions and changes regarding labels, as well as the latest LCode version.
Post19-05-2024, 13:38    Subject: VCDS German 23.11.0 Update Quote
VCDS software version 20240514 is now available online and includes the usual updates and changes regarding labels.
Post31-01-2025, 16:48    Subject: VCDS German 23.11.0 Update Quote
Help with VCDS update problems:
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS German 23.03. Update On-Board Diagnostics (OBD)
No new posts VCDS 22.10.0 German Trial Version On-Board Diagnostics (OBD)
No new posts VCDS Update 20.12.0 On-Board Diagnostics (OBD)
No new posts VCDS RKS Update mit MAC und WIN XP On-Board Diagnostics (OBD)
