Sensorik fuer Oeltemperatur | Posts 48+
Go to page: Previous  1, 2, 3, 4
MikeF
Post13-11-2003, 10:44    Subject: Quote
Okay, here's the translation:
'Again: VW partially coats the parts, and during a regular oil change, they normally replace the entire screw.' Exactly for that reason.
Greetings.
Post13-11-2003, 10:57    Subject: Quote
MikeF wrote:
Again: VW partially coats the parts, and during a regular oil change, they normally replace the entire screw. Exactly for that reason.
Greetings
Avatar-Jan6K
Post14-11-2003, 17:51    Subject: Quote
Hello everyone,
Especially after Ulf's story and all my own considerations about isolation, I've now come around to Dieter's idea (thanks again, @Dieter!).
To the metal experts: Do you consider a soldered brass tube to be risky due to the electrochemical series?
It will eventually replace the probe. Therefore, it shouldn't touch anything or come into contact with metal anywhere, and the guide above is made of plastic.
Jan.
P.S.: If I'm finished and anyone is interested, I'll write a report.
1Z5 CFHF / AHB H4D
Avatar-Jan6K
Post15-11-2003, 22:12    Subject: Quote
Hello everyone,
And so, I continue to flood this thread with my posts.
How do you like the level sensor at the bottom of the pictures? http://members.aol.com/wernersmail/werners-2cv6/Tipps___Tricks/tipps___tricks.html It's self-built based on Dieter's idea and suggestions from the website, using a brass tube from the hardware store (1 Euro and a bit), a PT100 sensor from Conrad (5 Euros and a bit), two silicone measurement hoses (1 Euro each), and a little bit of silicone for insulation. Since I already had this strange probe device from Conrad, I took it apart and reused some of its components (see pictures).
The internal workings weren't straightforward because a 4 mm tube is quite narrow, so the initial idea of isolating the sensor and solder joints with silicone and then inserting everything didn't work. Instead, I inserted it without any insulation, then pushed some silicone in behind it with pressure, and then soldered it in place. I wasn't sure if it would actually work, but it held up during the soldering process and all the tests (boiling water, etc.).
The response time is excellent - when I hold the cold rod in boiling water, I see the corresponding reading after just 10 seconds.
As I said, I can provide more detailed information if needed.
Later, I'll use a file to create the markings, and then everything will be correct.
Jan.
 Der gesamte Stab
 File size:  43.1 KB
 Viewed:  1380 times
 Die verloetete Spitze
 File size:  68.55 KB
 Viewed:  1448 times
 Das umgebaute Oberteil des Conrad-Peilstabes
 File size:  65.5 KB
 Viewed:  1474 times
1Z5 CFHF / AHB H4D
MikeF
Post16-11-2003, 8:58    Subject: Quote
'Normal' means that the screw replacement is intended. During the service, Fritzi wants to replace the O-ring, but discovers that it's not available individually, so she reuses the old screw because the new one is not in stock. It also happens icon_rolleyes.gif.
No new posts Audi A3 8P Oil Temp Sensor CFGB Diesel Engine Technology
No new posts Ibiza 6K: LDA & Oil Temp - Photos & Guide Diesel Engine Technology
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Fuel injectors for 130 PD? Diesel Engine Technology
