T5 - Radiator fan running constantly - Error code P0480
Derkleinenils
Post22-06-2024, 20:20    Subject: T5 - Radiator fan running constantly - Error code P0480 Quote
Maybe someone can help me, as I'm stuck and can't seem to make any progress. "On my T5 Biturbo (manufactured in 2014), the radiator fan is constantly running as soon as the ignition is turned on."
I have already performed a visual inspection of the cables (to check for damage, possibly from rodents), and all the fuses are still okay, especially fuse number 22.
Here's the translation:
"This entry is quite peculiar."
"Heat extraction temperature in the cooling system: -273.1 °C".
Is the sensor broken? But which one?
Thank you for your support!
According to VCDS, I have the following errors.
Address 01: Engine Control Module
Label file: DRV\03L-906-022-CFC.clb
Control unit part number: 03L 906 019 HM. Hardware: 03L 907 309 L.
Part and/or version: R4 2.0l BTD H38 9983
Encoding: 0125401A233601080000
Operating number: WSC 47887 006 1048576
ASAM Dataset: EV_ECM20BTD01103L906019HM 004008 (VN75)
ROD: EV_ECM20BTD01103L906019HL_004.rod
VCID: 7DA6FFF46D724882444-8028
"1 error found:"
4527 - Radiator fan control 1
P0480 00 [00101111] - Electrical fault.
confirmed - checked since last deletion.
Environmental conditions:
Error priority: 2
Error frequency: 1
Mileage: 167,430 km
Date: 2000.00.00
Time: 00:00:00
Motor speed: 0.00 rpm.
Normalized load value: 0.0%
Vehicle speed: 0 km/h
Coolant temperature: 20 °C
Intake air temperature: 23 °C
Ambient air pressure: 930 mbar.
Voltage at terminal 30: 11.980 V.
Lost count after OBD: 40
Air mass: Target value: 840.0 mg/stroke.
Coolant temperature at the radiator outlet: Actual value: 19.6 °C.
Outside temperature: 25.0 °C
Cooler fan 2: Control: 0.00%
Cooler fan 1: Control: 10.00%
Fuel temperature: 22.9 °C
Readiness: 0100 0000
Monday, June 17, 2024, 12:50:33:12902
VCDS version: RKS 23.11.0 is running on Windows 11 x64.
http://shop.dieselschrauber.org/en
Address 08: Climate Control/Heating Module. Label file: DRV\7E5-907-040.clb
Control unit part number: 7E5 907 040 AC. Hardware: 7E5 907 040 AC.
Component and/or version: Climatronic T5 H19 0407.
Encoding: 0000000103
Operating number: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003 (VN75)
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: 698EBBA409FAC42298C-803C
2 error codes found:
13701888 - Functionality restriction due to received error value.
U1113 00 [00001001] - -
[Engine Control Unit - please read the error memory.]
Error priority: 6
Error frequency: 8
Lost counter: 127
Mileage: 167,430 km
Date: 2110.14.00
Time: 11:40:38
9478657 - Control of the rear fresh air blower.
B10A2 01 [00001000] - Electrical fault.
Sporadically - confirmed - checked since last deletion.
Error priority: 2
Error frequency: 13
Lost Count: 167
Mileage: 167487 km
Date: 2110.14.00
Time: 13:57:15
T5 Biturbo CFCA, Skoda 3T5, GL 350 Blutec
Herbert likes this.
Post23-06-2024, 16:40    Subject: T5 - Radiator fan running constantly - Error code P0480 Quote
For a vehicle manufactured in your year, the radiator fan control unit should be integrated into the fan assembly.
If there are no visible damages to the wiring, I would replace the radiator fan.
First, definitely remove the front bumper/radiator cover and check the wiring. It seems to be a more common issue that the cable is damaged due to friction.
The -273°C value might simply be an arbitrary, recorded boundary condition, and it's not always something to be taken at face value.
Does the high-pressure refrigerant system in the air conditioner work?
Derkleinenils
dieselschrauber and Herbert likes this.
Post01-07-2024, 12:45    Subject: Error found :-) Quote
Thank you for the tip!!! I re-examined all the cables in detail, and sure enough: a small control wire was broken. It's working again icon_smile.gif.
 File size:  2.38 MB
 Viewed:  3720 times
Post02-07-2024, 7:20    Subject: T5 - Radiator fan running constantly - Error code P0480 Translating...
[Translating...]
No new posts Dashboard warning light for airbag "OFF" is constantly il... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fan Runs Until Battery Dies - VW Touran 2.0 TDI Diesel Engine Technology
No new posts Vibrating Cooler Fan: Troubleshooting & Fixes Diesel Engine Technology
No new posts Passat 3 BG 1.6 electric radiator fan Electrical Systems, Vehicle Electronics, Multimedia
No new posts Is My CPU Cooler Fan Broken? Diesel Engine Technology
