VW TDI V10 won't start
TRex5.0
Post03-08-2024, 13:16    Subject: VW TDI V10 won't start Quote
Hello everyone, my "Lady" (my car) had a leak after more than 306,000 km. So, I took it apart and removed the powertrain, along with the auxiliary pump, camshaft sensor, water pump, etc. I also replaced the O-rings on the PD units.
After re-installation, the fuel system (035) was bled, and it started. After a 5-10 minute warm-up period, I discovered a leak in the right fuel distributor (O-ring).
Subsequently, I replaced all the O-rings there, re-bled the system, and then, yes, it hasn't started since.
Some errors are secondary issues because the engine won't start, or because the car hasn't been moved (steering angle sensor), the air conditioning hasn't been filled yet, the rear door button has already been replaced...
I also can't understand the headlight module. The batteries have been disconnected and reconnected according to regulations.
Greetings
Volker
VCDS displays the following error codes:
Address 01: Engine Electronics Label file: DRV\070-906-016-BLE1.clb
Part Number SW: 070 *** 016 DH HW: 070 906 016 DH
Part Number: V10 5.0L EDCA001AGMªA251
Revision: --H05--- Serial Number: VWX3Z0G3657265
Encoding: 0010575
Operating Number: WSC 76112 146 85110
VCID: 112E1BB00B97341E5C-5140
VINID: 9E65EAAAA1DCA885000C01011438A30E82
2 error codes found:
005734 - Valve for Pump/Nozzle Cylinder 1 (N240)
P1666 - 000 - Electrical Fault in Circuit - Warning Light ON
Environmental Conditions:
Error Status: 11110000
Error Priority: 1
Frequency of Errors: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:57:36
Speed: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.56 V
Temperature: 28.8°C
(no unit): 128.0
005735 - Valve for Pump/Nozzle Cylinder 2 (N241)
P1667 - 000 - Electrical Fault in Circuit - Warning Light ON
Error Priority: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:57:37
Speed: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.56 V
Temperature: 28.8°C
(no unit): 128.0
Readiness: 0 0 0 0 1
Address 02: Transmission Label file: DRV\09D-927-750.clb
Part Number SW: 09D 927 750 EL HW: 09D 927 750 EL
Part Number: AL 750 6A 0989
Revision: 00H61000 Serial Number:
Encoding: 0004456
Operating Number: WSC 31414 790 00001
VCID: 7CF05A043C1529769F-5140
No error codes found.
Address 03: Brake Electronics Label file: 7L0-907-379-MK25E1.clb
Part Number SW: 7L0 907 379 K HW: 7L0 907 379 K
Part: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Encoding: 0010626
VCID: 418EEBF01C77849E8C-8014
1 Error found:
01826 - Input for Steering Angle (G85); Power Supply KL30
000 - -
Error Status: 01100000
Error Priority: 2
Frequency of Errors: 5
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:39:56
Number: 128
Number: 4353
Number: 294
Number: 3
Address 05: Access/Start Report Label file: DRV\3D0-909-13x-05.lbl
Part Number SW: 3D0 909 137 D HW: 5WK 485 05
Part Number: 23 Kessy 6840
Revision: 68406620 Serial Number: VWX3Z0G3657265
Encoding: 0147688
VCID: 285856549F0D55D6AB-807C
Subsystem 1 - Part Number: XXXXXXXXXXX
Component: ELV XXXX
00179 - Antenna, Driver's Side, for Access and Start Authorization (R134)
011 - Interruption
00180 - Passenger Side Antenna for Access and Start Authorization (R135)
011 - Interruption
Address 06: Vehicle Seating Label file: None
Part Number: 7L0 959 760
Part: Seat Adjustment 0701
Operating Number: WSC 00000 000 00000
VCID: 77FA452802330A2EF2-8022
Address 08: Climate/Heating Control Label file: DRV\7L6-907-044.clb
Part Number: 7L6 907 044 AE
Part: CLIMAtronic 2+2 4326
Encoding: 0000020
Subsystem 1 - Part Number: 7L6 907 049 F
Component: CLIMAtronic FOND 0503
3 error codes found:
02508 - Temperature sensor for refrigeration unit (G454)
010 - Interruption/Short to Plus
00229 - Refrigerant Pressure
002 - Lower limit exceeded
00445 - Refrigerant Leak
015 - Currently not verifiable
Temperature: 52.0°C
Speed: 0 /min
Pressure: 0.0 bar
Last: 0.0 %
Temperature: 27.0°C
Temperature: 27.0°C
Last: 0.0 %
Temperature: 34.0°C
Address 09: Central Electrical Label file: . DRV\7Lx-937-049-V2.clb
Part Number SW: 7L6 937 049 AG HW: 7L6 937 049 AG
Component: J519 2000
Revision: -1004--- Serial Number: --------------
Encoding: 600004003B3219000000000000000000
VCID: 010E2BF05CF7449ECC-8054
01498 - Lamp for standing light on the right (M3)
011 - Interruption
01497 - Headlight bulb, front right (M7)
011 - Interruption
02499 - Headlight dimmer, right (V295)
011 - Interruption
Address 11: Engine Electronics 2 Label file: DRV\070-906-016-BLE2.clb
Part Number: V10 5.0L EDCA001AGSªA251
Encoding: 0010575
1 Error found:
013089 - Control for 2 Valve Pump/Nozzle
P3321 - 000 - Electrical Fault in the Circuit - Warning Light ON
Error Priority: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:57:32
Speed: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.64 V
Binary Value: 00010001
Temperature: 28.8°C
Binary Value: 00010000
Address 13: Distance Control Label file: None
Part Number SW: 7L6 907 567 A HW: 7L6 907 567 A
Part Number: AC201 RDW 1 031 0382
Revision: 00031000 Serial Number: 00000000014674
Encoding: 0010000
VCID: 3C709A047B95E976DF-8068
Address 15: Airbag Label file: 7L0-959-655.lbl
Part Number SW: 7L0 959 655 HW: 7L0 959 655
Part Number: J234 37 VW8T 0250
Revision: 92011025 Serial Number: 0039P002PKHF
Encoding: 0013111
VCID: 7AFC5C1C312117468D-802E
Address 16: Steering Wheel Electronics Label file: DRV\7L6-953-549.lbl
Part Number: 7L6 953 549 G
Part Number: J527 3601
Encoding: 0011222
VCID: 4382E1F8066B968E9E-8016
Address 17: Relay Module Installation Label file: DRV\7L6-920-xxx-7L6.lbl
Part Number SW: 7L6 920 885 Q HW: 7L6 920 885 Q
Component: J285 COMBINATION INSTRUMENT 7520
Revision: KHH06V02
Encoding: 0007111
Company Number: WSC 00011 888 06946
VCID: 4A9CCCDC254147C65D-801E
Address 18: Electric Heater Label file: DRV\7L6-819-008.clb
Part Number: 7L6 819 008 H
Part: Standheizung E1MAC 0425
Encoding: 0000000
Operating Number: WSC 20914 146 93062
VCID: 3B7299187A9BEE4ED6-806E
Address 19: Diagnostic Interface Label file: . DRV\6N0-909-901-7L.clb
Part Number SW: 6N0 909 901 HW: 7L6 920 885 Q
Part Number: J533 GW-K-CAN TP20 7520
Encoding: FFF6EFBDDB056002
VCID: 70E87E34635D5D1633-8024
Address 22: Allrad Label file: DRV\0AD-927-755.lbl
Part Number: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 010E2BF05BF7449ECC-5122
Address 28: Heating/Air Conditioning here.
unavailable
Address 34: Level Control Label File: DRV\7Lx-907-553-34.clb
Part Number: 7L0 907 553 J
Part: AIR FILTER - CDC - 3C3P1 3125
Encoding: 0015541
VCID: 3A7C9C1C71A1D746CD-806E
1 Error found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 36: Seat Adjustment Label file: None
Part: Seat Adjustment 0703
Address 37: Navigation (J0506) Label file: . DRV\1T0-035-680.clb
Part Number SW: 7L6 035 680 C HW: 7L6 035 680
Part: RNS-MID H74 5238
Revision: AB001001 Serial Number: VWZ6Z7G9249044
Encoding: 02050000010000020000
Operating Number: WSC 20914 146 62127
VCID: 326CB43C6DD12F0605-8066
Subsystem 1 - Part Number: 1T0 051 859 AS
Part: EU West V17 8557
Address 3C: Lane Change Label file: DRV\7E0-907-566-V1.clb
Part Number SW: 7L6 907 566 B HW: 7L6 907 566 A
Part Number: J0769_SWA_MasterH10 0070
Revision: 00H10000 Seriennummer: 6PZ 009 014-01
Encoding: 0000151
Subsystem 1 - Part Number: 7L6 907 568 B
Part Number: J0770_SWA_Slave_H08 0070
Subsystem 2 - Serial Number: 6PZ 009 014-21
Subsystem 3 - Serial Number: 3F10.09.0700H0800000010260ÿ
Subsystem 4 - Serial Number: 010260ÿ
Address 46: Comfort System Label file: 7L0-959-933.clb
Part Number: 7L6 959 933
Part Number: 13 HSG 7124
Encoding: 0000069
VCID: 7F0AAD082D03326EBA-4B1C
Subsystem 1 - Part Number: 7L0 959 701 P
Component: Door Control Device FS 6302
Subsystem 2 - Part Number: 7L0 959 702 P
Component: Door Control Device BF 6302
Subsystem 3 - Part Number: 7L0 959 703 D
Component: Door Control Device HL 0201
Subsystem 4 - Part Number: 7L0 959 704 D
Component: Door Control Device HR 0201
Subsystem 5 - Part Number: 7L0 907 719 A
Component: Tilt Sensor 0020
Subsystem 6 - Part Number: 7L6 951 171 B
Part: Interior Sensor 0020
1 Error found:
00893 - Latch/Hatch Handle (E234)
007 - Short Circuit to Ground
Address 47: Sound System Label file: DRV\7Lx-035-4xx-47.lbl
Part Number SW: 7L6 035 466 A HW: 7L6 035 466 A
Component: DSP 10 Channel 0003
Revision: 00001000 Serial Number: 00000000004443
VCID: 326CB43CADD12F0605-8066
4 Error codes found:
00870 - Subwoofer, front left (R21)
011 - Interruption
Error Status: 01101011
Error Priority: 5
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:53:19
00871 - Subwoofer at front right (R23)
011 - Interruption
Error Priority: 5
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:53:19
00872 - Subwoofer, rear left (R15)
011 - Interruption
Error Priority: 5
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:53:19
00873 - Rear Right Subwoofer (R17)
011 - Interruption
Error Priority: 5
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:53:19
Address 55: Light fixture control. Label file: 7L6-907-357-A.lbl
Part Number SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS Control Unit 0001
Revision: H02 Seriennummer:
Encoding: 1288195
VCID: 397E831074A7DC5EC4-806C
Subsystem 1 - Part Number: 7L6 941 329 B Label File: 3D0-941-329.CLB
Part: AFS-Lst.-Module l X008
Encoding: 00000019
Subsystem 2 - Part Number: ID-R is missing Label file: ID-55-02.CLB
Component: AFS-Beam-Module r ....
Encoding: 00000255
5 error codes found:
02234 - Performance Module Headlight Right (J66)
004 - No signal/communication - Warning light ON
Error Status: 11100100
Error Priority: 2
Frequency of Errors: 3
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:43:29
Voltage: 12.92 V
Speed: 0.0 km/h
SECTION 1
01042 - Control unit not coded
000 - - - Warning light ON
Error Status: 11100000
Error Priority: 2
Lost Count: 239
Time: 0
invalid
invalid
invalid
02656 - Headlight Module Left (J667) not coded
Error Priority: 2
Lost Count: 239
Time: 0
invalid
invalid
invalid
02657 - Performance Module Headlight Right (J66 not coded)
Error Priority: 2
Lost Count: 239
Time: 0
invalid
invalid
invalid
01539 - Headlights not adjusted
005 - No or incorrect initial setting/adaptation - Warning light ON
Error Status: 11100101
Error Priority: 2
Lost Count: 239
Time: 0
invalid
invalid
invalid
Address 56: Radio (J0506) Label file: . DRV\1T0-035-680.clb
Address 57: TV Tuner Label file: DRV\7L6-919-148.clb
Part Number SW: 7L6 919 148 HW: 7L6 919 148
Component: TV Tuner 0120
Revision: R0H17000 Serial Number: 93900500007001
Encoding: 0000801
VCID: 79FE431030271C5E84-802C
Address 68: Wireless Electronics Label file: 7L0-955-119-V2.clb
Part Number: 7L6 955 119
Part: J400__ Front Wiper 5101
Encoding: 0000341
VCID: 77FA452806330A2EF2-8022
Subsystem 2 - Part Number: 1K0 955 559 AF Label file: DRV\1K0-955-559-AF.CLB
Part Number: RLS 180907 046 0204
Encoding: 00208933
Address 6D: Rear Door Label file: DRV\7L6-959-107.clb
Part Number SW: 7L6 959 107 B HW: 7L6 959 107 B
Part Number: J605 REAR DOOR 1310
Revision: --H05--- Serial Number: --------020285
Encoding: 0122110
03277 - Function Limitation Due to Missing Standby Information
000 - -
Error Priority: 3
Lost Count: 239
Time: 0
02841 - Hydraulic Unit
Error Status: 01100111
Error Priority: 3
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:44:11
03074 - Actuator for tailgate tilt (G549)
006 - Short circuit after plus
Error Status: 01100110
Error Priority: 3
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:44:11
Address 6E: Quantity/Service Roof Label file: None
Part Number SW: 7L6 919 044 R HW: 7L6 919 044 R
Part Number: J702 Roof Display 0400
Revision: --30004S Serial Number: 00000000034046
VCID: 4684F8EC3159A3A6B9-8012
Address 76: Parking Assist Label file: Navigation failed!
Part Number: 7L0 919 283 F
Part: 0D Parking Assist 1107
Address 77: Telephone Label file: DRV\3C0-035-730.lbl
Part Number SW: 5N0 035 730 A HW: 5N0 035 730 A
Component: J412 4100
Revision: 00015000 Serial Number: 0000B7A070677
Encoding: 0020041
VCID: 2644586C911943A699-8072
Ende----------------------------(Duration: 04:50)-----------------------------
Touareg TDI V10 BLE
Post03-08-2024, 13:27    Subject: VW TDI V10 won't start Quote
Hello Volker,
Environmental conditions:
Error Priority: 1
Error Frequency: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:57:36
RPM: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.56 V
Temperature: 28.8°C
(no unit): 128.0
Error Priority: 1
Error Frequency: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.02
Time: 00:57:37
RPM: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.56 V
Temperature: 28.8°C
(no unit): 128.0
The probability is high that the failure is due to these error entries. If the engine control unit detects a short circuit in the injectors, I can easily imagine that, in order to protect the power amplifier stages in the ECU, no engine start will be allowed.
Therefore, check the wiring to the injectors and also inspect the wiring harness for any chafing or damage. In some models, the wiring harness from the engine to the ECU (or ECUs) could rub against a metal edge and create a short circuit against the vehicle's chassis. Therefore, it may be more complex to expose the wiring harness in order to identify such issues.
You can delete the error messages; they will reappear if the underlying cause still exists. icon_biggrin.gif
Just to be safe, you could also measure the injectors. However, a short circuit or open circuit seems much less likely here than in the wiring harness and connectors.
Best regards, Rainer
Post03-08-2024, 13:30    Subject: VW TDI V10 won't start Quote
PS: You have corresponding errors in both ECUs (addresses 01 and 11). Possibly, the cause lies where both cable harnesses go towards the injectors.
TRex5.0
Post04-08-2024, 11:17    Subject: VW TDI V10 won't start Quote
Hello everyone,
Thank you very much for the quick response.
Due to the design, it is not possible to quickly access the interface or the cable harness in the cylinder head. I will pretend to be a mechanic and open the right bank to check for repairs, even though the ignition is only switched on.
conduct a scan
One more question regarding the starter motor's starting speed of 147 U/min. Is this too low and does it cause the starting process to fail? I haven't been able to find any information about the minimum RPM.
Greetings
Volker
Touareg TDI V10 BLE
Post05-08-2024, 23:52    Subject: VW TDI V10 won't start Quote
TRex5.0 wrote:
Hello everyone, Thank you very much for the quick response.
conduct a scan
Greetings
Volker
"it depends"
In some engine control units, the engine will never start when the coolant is warm.
Try starting with the coolant temperature sensor disconnected.
"This would, of course, present a new problem: the starting RPM needs to be significantly higher."
TRex5.0
Post15-08-2024, 23:56    Subject: VW TDI V10 won't start Quote
Update:
I opened the valve cover and could see that the connectors for cylinders 1 and 2 were only loosely attached to the PD, and after further inspection, I found that the connector for cylinder 3 could be easily removed.
So, I have replaced the PD cable harness and immediately checked for error codes in the VCDS. None were found. Reassembly and starting the engine with the new battery. Then the following picture emerged:
Short Version:
Encoding: 0010575
013111 - Motor/Motor Data Bus
P3337 - 000 - Unplausible Message - Warning Light ON
Error Priority: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 03:50:43
Speed: 966 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 13.60 V
(no unit): 0.0
(no unit): 0.0
006407 - Data Bus
P1907 - 000 - Engine/Engine Fault
Error Priority: 2
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 03:50:43
Speed: 966 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 13.60 V
Torque: 442.4 Nm
Torque: 0.0 Nm
Encoding: 0004456
Revision: 00H53001
Encoding: 0010626
1 Error found:
01826 - Gear for Steering Angle (G85); Power Supply KL30
000 - -
Error Priority: 2
Frequency of Errors: 24
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 02:37:40
Number: 128
Number: 4353
Number: 294
Number: 5
Encoding: 0147688
Component: ELV XXXX
011 - Interruption
011 - Interruption
Encoding: 0000020
Temperature: 52.0°C
Speed: 0 /min
Pressure: 0.0 bar
Last: 0.0 %
Temperature: 31.0°C
Temperature: 31.0°C
Last: 0.0 %
Temperature: 29.0°C
unavailable
Encoding: 0010000
1 Error found:
01316 - Brake Control Unit
013 - please read fault codes - Sporadisch
Error Status: 00101101
Error Priority: 3
Lost Count: 24
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 03:43:35
Number: 3
Encoding: 0013111
Encoding: 0011222
Revision: KHH06V02
Encoding: 0007111
Encoding: 0000000
1 Error found:
01342 - Engine Control Unit 2 (Slave 1)
Error Status: 01100100
Error Priority: 2
Lost Count: 239
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 03:43:25
Backwards out of the hall, forward gear, the engine diesels and won't start. icon_redface.gif icon_twisted.gif
This morning, the vehicle was disconnected from the power source for approximately 1 hour. Afterwards, the errors in the engine control units could be cleared. Starting attempt: simply turning the key to the right position did not work. When pressing the Start/Stop, the starter motor engages, but the engine does not start.
VCDS displayed the following image (abbreviated:
Encoding: 0010575
1 Error found:
005737 - Valve for Pump/Nozzle Cylinder 4 (N243)
P1669 - 000 - Electrical Fault in Circuit - Warning Light ON
Error Priority: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 00:48:03
Speed: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.26 V
Temperature: 24.3°C
(no unit): 128.0
Encoding: 0004456
Revision: 00H53001
Encoding: 0010626
1 Error found:
000 - -
Error Priority: 2
Lost Count: 240
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 00:41:03
Number: 128
Number: 4865
Number: 294
Number: 3
Encoding: 0147688
Component: ELV XXXX
011 - Interruption
011 - Interruption
Encoding: 0000020
Temperature: 52.0°C
Speed: 960 /min
Pressure: 0.0 bar
Last: 0.0 %
Temperature: 33.0°C
Temperature: 34.0°C
Last: 0.0 %
Temperature: 89.0°C
Encoding: 0010575
1 Error found:
Error Priority: 1
Lost Count: 255
Odometer: 306688 km
Time: 0
Date: 2024.08.13
Time: 00:47:58
Speed: 147 /min
Speed: 0.0 km/h
Last: 0.0 %
Voltage: 10.18 V
Temperature: 24.3°C
Where is the worm? I am grateful for any assistance.
Greetings
Volker
Touareg TDI V10 BLE
Post16-08-2024, 9:17    Subject: VW TDI V10 won't start Quote
Thank you for the feedback!
I opened the valve cover and could see that the connectors for cylinders 1 and 2 were only loosely attached to the PD, and after further inspection, I found that the connector for cylinder 3 could be easily pulled out.
Therefore, I try to do as many tasks as possible myself, which saves me time, money, and stress.
Regarding the errors in the 1st ECU (address 01) and the data bus error... please check what the 2nd ECU says about it. She says:
unavailable
She says nothing.
Likely, a cable issue between the ECUs, if the other one is installed and not located in the back seat. icon_cool.gif
alevuz
Karma: +32 / -0   Thank you, like it!
dieselschrauber likes this.
Post26-08-2024, 9:01    Subject: VW TDI V10 won't start Quote
Hi... Wow, that's a real mess... There was a problem with bent pins in the engine control units... A V10 can also run with 8 PDEs if it gets enough fuel... If you have any air getting in there, it could take some time... There's a PDE status somewhere in the data blocks... I'm sorry, I don't remember where... I've never seen a completely defective PDE... Have you removed the PDE? If so, did you definitely set them up correctly again? I would try to bleed the two fuel pumps (high pressure, i.e. those mounted on the camshafts) in addition to bleeding them... Also at the output of each pump... Are the batteries good? Are the intake valves open? Are the fuel pump fuses in the tank OK? If everything is OK... accelerate fully, then 15 seconds, then cool for 5 minutes, etc.... Are all the connectors to the LMM / LD / etc. securely plugged in? Are both engine control units accessible via VCDS? Sorry for the unclear writing. Best regards, Manfred
If the 2 engine control units are not accessible with VCDS, then there is a problem there!! Have you worked on the wiring harnesses? Do they fit tightly on the right side...? And again: Do you have good batteries (2)? The starting procedure for the V10 is quite complicated, I find starting a helicopter much easier.... just out of curiosity... Have you ever tried to start it in an emergency...? This procedure is in the manual.... Press the button and then move the key to the left - osä... and please don't be angry with me NOW: BUT, if you have already incorrectly connected 3 PDEs, I would suggest taking a break and going for a coffee icon_wink.gif
Touareg V10 TDI (AYH)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car won't start, lights not working Diesel Engine Technology
No new posts 3.0 TDI ASB: Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts AFN won't start: Troubleshooting guide Diesel Engine Technology
No new posts A6 5-cylinder. TDI won't start Diesel Engine Technology
