Gear Oil: Top Up at First Service?
eike
Post17-11-2003, 10:30    Subject: Gear Oil: Top Up at First Service? Quote
Hey fellow mechanics,
My wife's Golf 4 TDI with engine code AXR was just taken for its first (long-life) service at the dealership, and it has 33,800 km (almost 2 years old).
There, it was determined that the transmission oil level was not okay, and half a liter of oil was added. icon_eek.gif
Could that be the case? Did VW perhaps put too little oil in at the factory? Or is the car now even running with too much oil in the transmission? Is this harmful or disadvantageous (increased fuel consumption)? icon_question.gif
The workshop did not report any leaks or similar issues.
What is your opinion on that?
Greetings.
Eike.
Translated on 15-09-2026, 23:13.
Post17-11-2003, 10:56    Subject: Gear Oil: Top Up at First Service? Quote
Hi Eike,
My A3 was also skimped on. icon_confused.gif I also had to top up quite a bit until the inspection opening.
Too much oil isn't good either, firstly because it increases fuel consumption, and secondly, it will eventually leak out somewhere.
Translated on 15-09-2026, 23:14.
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts SDI Injection Pump: First Generation On-Board Diagnostics (OBD)
No new posts No Turbo Lag: First Drive Experience Upload
No new posts VAG-COM for Ford Galaxy: First Gen Diagnostics On-Board Diagnostics (OBD)
No new posts The climate is no longer cooling as it did in the beginning Diesel Engine Technology
