Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
19-11-2024, 18:28 Subject: Ross-Tech USB interface not found! |
Hello forum, my VCDS is not starting anymore. See photos.
I would be very grateful for any help. Wolfgang.
| Description: |
| File size: |
6.23 MB |
| Viewed: |
1726 times |
| Description: |
| File size: |
6.5 MB |
| Viewed: |
1760 times |
Profile PM Email |
Joined: 04/12/2002 Posts: 18068 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
19-11-2024, 20:23 Subject: Ross-Tech USB interface not found! |
Click on "More Information"?
Profile PM WWW Garage |
19-11-2024, 20:48 Subject: Ross-Tech USB interface not found! |
Hi Rainer, I clicked on "more information" and restarted my computer, but it's still not working. Greetings, Wolfgang.
Profile PM Email |
19-11-2024, 21:01 Subject: Ross-Tech USB interface not found! |
Yes, and what is displayed under "More Information"? The computer clearly states that it cannot load the driver because a specific setting is preventing it.
19-11-2024, 21:57 Subject: Ross-Tech USB interface not found! |
Everything is back to normal. I deleted the driver.
VCDS is operational again. Thank you for your help.
Best regards, Wolfgang.
Profile PM Email |
19-11-2024, 23:58 Subject: Ross-Tech USB interface not found! |
Schmierpfote wrote: | Everything is back to normal. I deleted the driver.
Greetings Wolfgang |
Well, maybe someone else has had the same problem and would be willing to explain what the issue was.
Possibly a driver for amd64 on an ARM system...
20-11-2024, 11:32 Subject: Ross-Tech USB interface not found! |
Hello Rainer,
I started an HP update, and after 20 minutes, the problems were resolved.
Thank you for your help. Wolfgang.
Profile PM Email |
20-11-2024, 13:07 Subject: Ross-Tech USB interface not found! |
Schmierpfote wrote: | Hello Rainer,
Thank you for your help. Wolfgang |
Okay, so something changed in Windows, and then it started working.
Okay, I understand.
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 198 Karma: +74 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
dieselschrauber and Herbert likes this. |
26-11-2024, 22:57 Subject: Ross-Tech USB interface not found! |
The problem is likely due to a security update for Windows 11. I don't know if Windows 10 also received that security update.
It's related to the core isolation feature, which can be disabled in the Windows settings under "Privacy and Security" -> "Device Security".
Profile PM Garage |
27-11-2024, 7:15 Subject: Ross-Tech USB interface not found! |
Hello Turbinchen,
I have Windows 11, and that was the reason for the problems.
Profile PM Email |
