A4 2.5 TDI G28 - No Signal
Post02-04-2025, 4:50    Subject: A4 2.5 TDI G28 - No Signal Quote
Hi.
Yesterday, I was preparing my silver A4 with an AKN engine for its inspection, so I started the engine, drove it out, and let it idle to warm up.
Suddenly, it starts making a sawing noise, and the filament starts flickering...
Briefly checked, G28 sensor shows no signal, crankshaft position sensor.
I tested two different, identical, and fully functional sensors, but the error persists.
If I clear the error code when starting the engine, the error memory is empty. However, as soon as the engine starts, the error code reappears.
I looked at another engine, and on its flywheel, there were only notches at specific intervals, but no pin or anything like that, which might be broken on my engine.
Three weeks ago, the Audi was still working perfectly.
Where could I start?
Thank you.
Post02-04-2025, 7:56    Subject: A4 2.5 TDI G28 - No Signal Quote
Harness and connector?
Post02-04-2025, 8:21    Subject: A4 2.5 TDI G28 - No Signal Quote
At first glance, it looks clean... and there are no signs of a weasel or anything like that.
I'm going to use an endoscope to look through the borehole of the G28 this afternoon.
Yesterday, everything was done in a hurry, and I only skimmed the information because of a lack of time.
Post02-04-2025, 17:02    Subject: A4 2.5 TDI G28 - No Signal Quote
I just quickly checked the extended measurement blocks using VCDS.
"G28" is displayed more frequently, and for all but one device, a constant speed is indicated.
When the engine starts to stall while idling, the VTG (Variable Turbine Geometry) valve also adjusts.
Post04-04-2025, 17:26    Subject: A4 2.5 TDI G28 - No Signal Quote
Unfortunately, there's no news.
Does anyone have any ideas?
Post04-04-2025, 18:52    Subject: A4 2.5 TDI G28 - No Signal Quote
Find out the pin configuration of the sensor and check if it needs to be powered by the operating voltage.
dieselschrauber likes this.
Post06-04-2025, 18:03    Subject: A4 2.5 TDI G28 - No Signal Quote
I've ordered some documents.
Post17-04-2025, 19:29    Subject: A4 2.5 TDI G28 - No Signal Quote
Here's a quick update: I've obtained the original repair manual from that era, a VAG diagnostic tool that connects to the wiring harness of the engine control unit, and the corresponding original wiring diagrams. Now, all I need is the peace, motivation, and time to actually troubleshoot the issue.
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kraftstoffabschaltventil (ALE) bekommt kein Signal. Was nun? On-Board Diagnostics (OBD)
No new posts T4 ACV performance only from 2500 RPM, no MAF signal On-Board Diagnostics (OBD)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
