Transmission Control Unit: Recording Issues
JohnRambo1980
Post21-07-2025, 8:12    Subject: Transmission Control Unit: Recording Issues Quote
Hello everyone,
I'm having a problem with my transmission and I want to log or record it.
Unfortunately, only an empty file is being created by VCDS.
Volkswagen Touareg 7P5, 4.2 TDI V8, manufactured in 2012.
Best regards, Raimund.
Translated on 07-08-2026, 15:09.
Post21-07-2025, 9:01    Subject: Transmission Control Unit: Recording Issues Quote
Hi there,
It's about this transmission (from your car scan).
Address 02: Transmission (J217)
Label file: | DRV\0C8-927-7XX-V1.clb
Part number SW: 0C8 927 750 J, Hardware number: 0C8 927 750 J.
Part: AL1000 AISIN 001 3667
Serial number: CVN: 4982F9E3
Encoding: 001168
Operating number: WSC 09536 006 1048576
ASAM Dataset: EV_TCMAL991031 002112
FILE: EV_TCMAL991031_002_VW52.rod
VCID: 33321F261BB58732929-8066
The actual topic here is:
Ich kann den Inhalt dieser URL nicht abrufen und übersetzen. Bitte gib mir den Text, den du übersetzt haben möchtest.
Can you access the extended measurement values for the transmission after selecting/opening the control unit?
Translated on 07-08-2026, 15:11.
JohnRambo1980
Post21-07-2025, 9:07    Subject: Transmission Control Unit: Recording Issues Quote
Hello Herbert,
Yes, I did that too.
I see those values as well, and I have selected them.
Recording started and is in progress.
Unfortunately, only the file is created without any measurement data.
Translated on 07-08-2026, 15:14.
Post21-07-2025, 18:27    Subject: Transmission Control Unit: Recording Issues Quote
Which measurement values did you check off?
Translated on 07-08-2026, 15:15.
JohnRambo1980
Post22-07-2025, 16:45    Subject: Transmission Control Unit: Recording Issues Quote
It worked once out of approximately 30 attempts.
The image shows the values that I want to record.
Raimund
 File size:  6.65 MB
 Viewed:  220 times
 File size:  6.65 MB
 Viewed:  183 times
Post25-07-2025, 8:45    Subject: Transmission Control Unit: Recording Issues Quote
If the transmission control unit's logging is causing problems, intermittent resets or power interruptions could be a possible cause. Before declaring the transmission control unit defective, I would carefully check the wiring to the power supply.
dieselschrauber likes this.
Post26-07-2025, 5:00    Subject: Transmission Control Unit: Recording Issues Quote
Hi there,
The two images don't convey anything meaningful. It's a flawed analysis.
First, take a Screenshot of the selected measurement values as they are displayed during the measurement (refer to the VCDS manual, Advanced Measurement Values).
Next, we'll proceed with selecting the `<Log>` option, entering a name, and specifying the file location (in `.csv` format), along with setting the start and stop times, always including screenshots.
Please provide the raw CSV file here.
Translated on 07-08-2026, 15:17.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Control Unit: No Reprogramming On-Board Diagnostics (OBD)
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
No new posts 1.6 TDI AGR module cannot be programmed Diesel Engine Technology
No new posts A6 4F ignition won't turn on Electrical Systems, Vehicle Electronics, Multimedia
