Unklare Sicherungsbelegung bei VW [Touran 1T, 04.2009] | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Dieselschrauber Bar
VAG
Karma: +9 / -0   Thank you, like it!
Post26-09-2025, 9:47    Subject: Quote
guste100 wrote:
If it's just about whether something is occupied or not: Just take a look inside the fuse holder. At least for the ones inside the car, you can see two silver contacts if the space is occupied. If it is not populated, only a pin connected to the power supply is visible, but not a pin for the load.
Thanks for the suggestion, but I've already tried that without success (as mentioned above), and it's not visible in the engine compartment.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. EPB Problem: Passat 3C, 2009 Model Transmission, Chassis, Body & Interior
No new posts Passat 2009 power loss Diesel Engine Technology
No new posts A6 4F, Year 2009, Rear Axle Oil Change Transmission, Chassis, Body & Interior
No new posts Particle filter emergency regeneration Audi FL 2009? Diesel Engine Technology
