Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
26-07-2021, 19:37 Subject: |
In your log, I only found a marker at 333.92 seconds. A little earlier, there's an entry that says "Charging pressure sensor between ND and HD turbocharger: adapted" (why not simply log the actual charging pressure?). The value is 2697 mbar.
It's possible that the engine control unit is completely shutting off the fuel injection in this situation, which could explain the loss of power.
Normally, this should also generate an error code in the engine control unit's memory.
Given the sudden jump in value, I'm ruling out any issues with the turbos themselves. Is the wiring to the pressure sensor okay and undamaged?
Translated on 20-07-2026, 10:03.
Profile PM WWW Garage |
Done1
14-07-2022, 14:49 Subject: |
Hi there,
Has the bug been fixed? I'm experiencing the same problem, but I can't find any errors.
Done.
Translated on 20-07-2026, 10:04.
Frank1986
dieselschrauber likes this. |
14-07-2022, 22:43 Subject: |
Hello, sorry for the late reply regarding what the error was.
While changing the oil with the engine running, I accidentally bumped the crankshaft position sensor, and the engine stalled.
I then had it replaced at a Volkswagen dealership, and so far everything is working perfectly again!
Thank you for your help.
Translated on 20-07-2026, 10:05.
16-07-2022, 18:02 Subject: |
Thank you for the feedback!
Translated on 20-07-2026, 10:06.
11-11-2025, 15:00 Subject: |
Maximilian wrote: | I wanted to leave a thank you here. I had the same problems with my Golf 7 2.0 TDI with a 6-speed DSG, manufactured in 2014, at just over 120,000 km.
No one at the workshop could help me because the problem only occurred sporadically and there was no error code stored in the system's memory.
I also fiddled with the crankshaft position sensor, and it sputtered briefly once. I then replaced the crankshaft position sensor, and since then everything has been running smoothly again .
Thank you!
Translated on 20-07-2026, 10:07.
