Skoda Rapid Tire Pressure Monitoring System
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
sims
Post25-01-2026, 18:28    Subject: Skoda Rapid Tire Pressure Monitoring System Quote
Hello everyone,
The tire pressure monitoring system light on our Skoda Rapid is constantly illuminated.
I've already tried resetting it using the built-in button, but unfortunately, the error keeps recurring.
Can I disable the light using VCDS?
A passive TPMS (Tire Pressure Monitoring System) is installed.
Thank you for your help.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
Log-PL-TMBEM6NH5F4519249-105728-001.txt
 File name:  Log-PL-TMBEM6NH5F4519249-105728-001.txt
 File size:  9.94 KB
 Downloaded:  185 times
Translated on 07-07-2026, 3:38.
Post27-01-2026, 11:18    Subject: Skoda Rapid Tire Pressure Monitoring System Quote
Hi.
Here's the translation:
"The wheel speed data, which can be accessed through the ABS/ESP system, must be reasonably consistent. The system detects differences in wheel speeds. Since this data is also needed for ABS/ESP, I advise against disabling the warning light, as a wheel speed sensor may be providing no signal or a poor signal. Also, check for large rust particles on the sensor and any damage to the wiring."
Translated on 07-07-2026, 3:39.
Karma: +1354 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-01-2026, 12:00    Subject: Skoda Rapid Tire Pressure Monitoring System Quote
Is that a 2022 Skoda? Perhaps RDK (Rim Diameter Compensation) is determined through sensors in the wheel, rather than wheel speed?
Translated on 07-07-2026, 3:40.
sims
Post27-01-2026, 17:11    Subject: Skoda Rapid Tire Pressure Monitoring System Quote
Sincerely
Thank you, but I'll wait until the tire change for that.
It's not urgent, just annoying.
Translated on 07-07-2026, 3:41.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Rapid: Problems with the Rear End? Transmission, Chassis, Body & Interior
No new posts Tire Pressure System Audi A4 B7 Door Control Unit On-Board Diagnostics (OBD)
No new posts Skoda Daytime Running Lights: Best Options Transmission, Chassis, Body & Interior
No new posts Skoda Cooking: Maggi Recipes & Car Kitchen Transmission, Chassis, Body & Interior
