Quote: |
33005 - Sensor 1 for NOx Bank 1.
P2201 00 [01100100] - implausible signal.
Sporadically - unconfirmed - checked since last deletion.
Environmental conditions:
Error priority: 2
Error frequency: 1
Mileage: 180,135 km
Date: 2026.07.01
Time: 16:13:41
Motor speed: 1100.25 rpm.
Normalized load value: 0.0%
Vehicle speed: 53 km/h
Coolant temperature: 85 °C
Intake air temperature: 25 °C
Atmospheric pressure: 990 mbar.
Voltage at terminal 30: 14.109 V.
Lost count after OBD: 40
Air mass at air mass flow sensor 1: 39.6 kg/h.
Average injection volume: 0 mg/stroke.
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stored Fault Code - Live Value: 38.11 %
Air mass sensor 1 bank 1 air mass: Raw value: 300.7 mg/stroke.
NOx sensor upstream of SCR catalyst: NOx concentration: 0 ppm.
NOx sensor after SCR catalyst: NOx concentration: 127 ppm.
NOx sensor upstream of SCR catalyst: Activation status offset diagnosis: not active.
NOx sensor before SCR catalyst: Supply voltage: 0.000 V
NOx sensor upstream of SCR catalyst: Offset correction factor: 0 ppm.
NOx sensor upstream of SCR catalyst: O2 concentration: 0.0000.
NOx sensor after SCR catalyst: Activation status, offset diagnosis: active.
NOx sensor after SCR catalyst: Supply voltage: 13.421 V.
NOx sensor after SCR catalyst: Offset correction factor: 121 ppm.
NOx sensor after SCR catalyst: O2 concentration: 0.0230 |
Is that normal? Check the extended measurement data blocks and the circuit diagram (or examine them) to see if there's a sensor that needs to be powered.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
