ABS hydraulic unit removal A4 B7 2.0 TDI, year 2006
MrMcFly79
Post30-08-2025, 14:27    Subject: ABS hydraulic unit removal A4 B7 2.0 TDI, year 2006 Quote
Hello everyone,
I would like to bleed the ABS block, but I cannot find the corresponding function under "03 Brake Electronics / 04 Basic Settings". Could it be that on the Audi A4, the pump can only be controlled via the actuator diagnosis? Does that mean that one can simply bleed the pump without specific instructions while it is in operation?
Greetings
Tobi
Karma: +805 / -0   Thank you, like it!
Post04-07-2026, 8:18    Subject: ABS hydraulic unit removal A4 B7 2.0 TDI, year 2006 Quote
Sure, I'll try. Please provide the text you want me to translate.
ABS bleeding with VCDS on an A4 B7 (2.0 TDI).
Step 1: Select the control unit, choose "03 - Brake electronics".
Step 2: Start basic setup, select "Basic settings" (04).
Step 3: Enter channel.
In the "Basic Settings" field, enter the channel number 001 (not "Display Group 001").
Important: Please enter channel 001 directly and click "Go!".
Translated on 04-07-2026, 8:19.
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Deals 2006: Best Offers & Savings On-Board Diagnostics (OBD)
No new posts TT Steering Wheel 2006 Transmission, Chassis, Body & Interior
No new posts AHK, starting system, model 2006 On-Board Diagnostics (OBD)
No new posts Bleed Diesel Filter: How To & Why Diesel Engine Technology
