PD Injector Data: 4-Cylinder Engine Performance (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 22:12
Target data for measurement blocks of 4-cylinder engines with pump-nozzle injectors (PD)
Engine codes: AJM, ATJ | ATD, AXR | AVB | ASZ | AVF, AWX
Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
(Manual) = manual gearbox, (Automatic) = automatic transmission, (FWD) = front-wheel drive, (AWD) = all-wheel drive
Measurement block 0 - Baseline values
MBFieldDescriptionAJM,ATJ LLAJM,ATJ VLATD,AXR LLATD,AXR VLAVB LLAVB VLASZ LLASZ VLAVF,AWX LLAVF,AWX VL
01Engine speed43..39150..13641..45 (manual) 38..42 (automatic)134..15436..42 (FWD) 41..46 (AWD)136..15041..45 (manual) 38..42 (automatic)134..15436..42 (FWD) 41..46 (AWD)136..150
2Start of injection124..13453..63113..13376..47120..13255..76113..13360..85113..13360..85
3Accelerator pedal position02550255025502550255
4Injection quantity11..40160..17211..33142..16411..33142..15311..33171..21911..33171..219
5Intake manifold pressure108..90245..197-181..22189..112187..211-206..25588..113206..255
6Atmospheric pressure223..183223..183--183..223183..223--181..222183..223
7Coolant temperature80..3580..3588..3688..3680..3580..3588..36< 8080..3580..35
8Intake manifold temperature189..51189..51--51..18951..189--51..18951..189
9Fuel temperature170..85201..85--85..17085..201--85..17085..201
10Intake air mass70..126245..25560..111> 24070..126> 24063..105> 24563..105> 255
Measurement block 1 - Baseline values at idle
11Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Injection quantity in mg/stroke3..113..93..93..133..9
3Delivery duration in °crank angle5..73..85..83..83..8
4Coolant temperature in °C80..11080..11080..11080..11080..110
Measurement block 2 - Operating state at idle
21Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)36..42 (FWD) 41..46 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Accelerator pedal position in %00000
3Operating state010010010010010
Measurement block 3 - Air masses / EGR at idle
31Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)36..42 (FWD) 41..46 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Air mass setpoint in mg/stroke230..420220..350230..420230..310230..310
3Actual air mass in mg/stroke230..420200..370210..420210..350210..350
4EGR valve duty cycle in %10..95-50..70-40..75
Measurement block 4 - Delivery start / Synchronization
41Engine speed in RPM830..9002850..3150860..940 (manual) 790..870 (automatic)2800..320036..42 (FWD) 41..46 (AWD)2850..3150860..940 (manual) 790..870 (automatic)2800..3200790..870 (FWD) 860..945 (AWD)2850..3150
2Delivery start setpoint1°BTDC..2°ATDC20°BTDC..23°BTDC4°BTDC..2°ATDC-16°..-25°crank angle2°BTDC..2°ATDC16°..22.5°BTDC4°BTDC..2.5°ATDC13..23°BTDC4°BTDC..2°ATDC13..21°BTDC
3Delivery duration setpoint in °crank angle5..720..233..819..245..819..22.53..816..283..816..28
4Synchronization angle in °crank angle-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3
Measurement block 8 - Injection quantities at full load
81Engine speed in RPM2850..31502800..32002850..31502800..32002850..3150
2Injection quantity, driver demand in mg/stroke50..5542..5242..5065..7065..70
3Torque limitation in mg/stroke44..4725..4739..4225..5147..51
4Smoke limitation in mg/stroke47..5216..3648..5216..5547..60
Measurement block 10 - Full load boost pressure
101Actual air mass in mg/stroke850..1050200..370800..1100800..1100210..350900..1250900..1250
2Atmospheric pressure in mbar910..1110--910..1110--910..1110
3Intake manifold pressure in mbar2000..2200--1900..2150-2100..26002100..2600
4Accelerator pedal position in %100-100100-100100
Measurement block 11 - Boost pressure control
111Engine speed in RPM2850..31502800..32002850..31502800..3200
2Boost pressure setpoint in mbar2000..21501900..21001900..21502200..2400
3Actual boost pressure in mbar2000..22001850..22501900..21502100..2600
4Boost pressure valve duty cycle in %45..9545..8055..7540..95
Measurement block 13 - Smooth running control at idle
131Smooth running regulator cylinder 1 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
2Smooth running regulator cylinder 2 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
3Smooth running regulator cylinder 3 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
4Smooth running regulator cylinder 4 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
Measurement block 18 - PD element status at idle
181PD element 1 status00000
2PD element 2 status00000
3PD element 3 status00000
4PD element 4 status00000
Source: community.dieselschrauber.org – Michael II
Translated on 09-08-2026, 11:24.
Ratings - PD Injector Data: 4-Cylinder Engine Performance
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts Measurement Data Blocks: Different Expected Values? Diesel Engine Technology
No new posts MKB AFB: Solldaten & Data Diesel Engine Technology
No new posts T5 AXE: Data Logging & Measurement Block Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
