VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 22:20
Target data for measurement blocks of 6-cylinder VE engines (VP44)
Engine codes: AFB | AKE | AKN
Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
Measurement block 0 - Baseline values
MBFDescriptionAFB LLAFB VLAKE LLAKE VLAKN LLAKN VL
01Engine speed30..36120..14032..36140..18030..36120..140
2Start of injection51..73109..14551..88> 12054..78109..145
3Accelerator pedal position025502550255
4Injection quantity10..30121..13410..30113..12710..30121..134
5Intake manifold pressure-181..221-187..215-181..221
6Atmospheric pressure------
7Coolant temperature80..3580..3580..4580..4580..3580..35
8Intake manifold temperature85..21685..216--85..21685..216
9Fuel temperature120..230120..230--120..230120..230
10Intake air mass53..98> 19250..70> 18540..120> 192
Measurement block 1 - Baseline values at idle
11Engine speed in RPM700..840700..840
2Injection quantity in mg/stroke3..93..9
3Quantity solenoid valve activation duration15..2515..25
4Coolant temperature in °C80..11080..110
Measurement block 2 - Operating state at idle
21Engine speed in RPM700..840700..840
2Accelerator pedal position in %00
3Operating state0010000100
Measurement block 3 - Air masses / EGR at idle
31Engine speed in RPM700..840700..840
2Air mass setpoint in mg/stroke210..385157..471
3Actual air mass in mg/stroke210..385157..471
4EGR valve duty cycle in %40..8440..84
Measurement block 4 - Start of injection
41Engine speed in RPM700..8402800..3200700..8402800..3200
2Start of injection setpoint1.1°..4.2°BTDC5..10°BTDC1.1°..4.2°BTDC5..10°BTDC
3Actual start of injection1.1°..4.2°BTDC5..10°BTDC1.1°..4.2°BTDC5..10°BTDC
4Injection start valve duty cycle3..7080..953..7050..95
Measurement block 8 - Injection quantities at full load
81Engine speed in RPM2800..32002800..3200
2Injection quantity, driver demand in mg/stroke45..4945..49
3Torque limitation in mg/stroke37..4237..42
4Smoke limitation in mg/stroke39..4739..47
Measurement block 10 - Full load boost pressure
101Actual air mass in mg/stroke> 750> 750
2Atmospheric pressure in mbar--
3Intake manifold pressure in mbar1850..22501850..2250
4Accelerator pedal position in %100100
Measurement block 11 - Boost pressure control
111Engine speed in RPM2800..32002800..3200
2Boost pressure setpoint in mbar1850..22501850..2250
3Actual boost pressure in mbar1850..22501850..2250
4Boost pressure valve duty cycle in %45..9545..95
Measurement block 13 - Quantity difference cylinders 1-3 at idle
131Quantity difference cylinder 2 vs 3 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0
2Quantity difference cylinder 1 vs 2 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0
Measurement block 14 - Quantity difference cylinders 4-6 at idle
141Quantity difference cylinder 6 vs 2 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0
2Quantity difference cylinder 4 vs 2 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0
3Quantity difference cylinder 5 vs 2 in mg/stroke-2.0..+ 2.0-2.0..+ 2.0
Measurement block 18 - Supply voltage at idle
181Injection pump supply voltage in V13..14.813..14.8
2Control unit supply voltage in V13..14.813..14.8
3Injection pump data0000000000000000
Source: community.dieselschrauber.org – Michael II
Translated on 08-08-2026, 23:02.
Ratings - VE Injection Pump Data: 6-Cylinder Engine Performance (VP44)
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Measurement Data Blocks: Different Expected Values? Diesel Engine Technology
No new posts Solldaten MKB AFB Diesel Engine Technology
No new posts Solldaten Messwerteblock T5 AXE Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
