Marc332
dieselschrauber likes this. |
15-08-2026, 13:44 Subject: Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015 |
Hello everyone,
We have a big problem: the fuel injection pump was removed without being secured from the rear.
The impeller (located within the chain case) has obviously sagged slightly, which means the high-pressure pump (CP4) cannot be mounted. While I can easily lift the impeller into the desired position with a screwdriver (the chain tensioner hasn't engaged), it doesn't stay in place. To access the impeller from the back, I would have to remove the entire turbocharger, which I honestly want to avoid.
Does anyone have any ideas on how to solve this problem?
Is there a way to position the pump rotor and apply tension via the crankshaft so that the rotor stays in place? It's essentially suspended like in a hammock and held by the chain, or perhaps by the driver-side engine mount (which connects to the camshaft)?
I would be very grateful for any helpful tips.
Best regards and have a nice weekend.
| Description: |
| File size: |
8.41 MB |
| Viewed: |
137 times |
Translated on 16-08-2026, 12:37.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
16-08-2026, 12:33 Subject: Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015 |
Hi, I'm not sure, maybe try lifting the impeller with a strong magnet? But make sure the magnet is securely attached, so it doesn't fall in or get stuck inside, which would create another problem.
Translated on 16-08-2026, 12:34.
Profile PM WWW Garage |
Marc332
16-08-2026, 12:52 Subject: Best SEO Agency: Find Top Agencies Now! |
Hi Rainer, no, that won't work. It requires completely removing the turbo and disconnecting the pump from the back. That's why I'm still looking for another solution. I don't think rotating the KW (wastegate) counter-clockwise will help; in the worst case, it could release the chain tensioner, which would be a disaster because then the engine might have to come out, or at least the transmission etc.
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe Grüße", which means "Warm greetings" in English.
Translated on 16-08-2026, 12:53.
