VW Passat Oil Pan Replacement: Lower Engine Mount
hansihanson
Post15-08-2026, 14:09    Subject: VW Passat Oil Pan Replacement: Lower Engine Mount Quote
Hello fellow 3BG diesel enthusiasts.
Volkswagen Passat 3BG, year 2002, 1.9 TDI, 130 hp, AVF engine, 6-speed manual transmission.
vorweg: der Beitrag steht jetzt in den Themen Motor UND Fahrwerk, weil es beides betrifft. Because:
I need help lowering the subframe/stabilizer (chassis) in order to change the oil pan (engine).
To replace the oil pan and hydraulic supports, I need to lower the engine cradle. What should I be aware of? I don't have a lift or pit. The oil pan is already loose. I'm not sure if I just need to support the engine cradle and then loosen the three large bolts on the front (left and right, of course). The rear bolts should remain in place to prevent misalignment, according to my current understanding.
Current setup: Car securely jacked up at the front, with the front wheels raised about 1-2 cm above the ground.
Have a jack ready to support the front of the transmission.
"Have a second jack ready to lift the front of the car further (underneath the air conditioning compressor, so you can remove the oil pan)."
With this setup, the oil pan can be removed relatively easily. However, there are still 2-4 cm missing, which I need to obtain from the lowered engine mount.
- Does the stabilizer need to be removed? If so, where exactly (is the center sufficient?), and at what point (before or after the mounting bracket screws)?
- What forces should I expect to apply to the stabilizer bar when the wheels are hanging freely (with a height difference of 1.5 cm from the ground)?
- What forces should I anticipate when lowering the generator carrier? I assume a jack needs to be placed under the carrier and used to carefully lower it after loosening the two 3-bolt fasteners?
Horror scenario:
I can't get the bracket attached with the 2x3 screws anymore, and I can't center the stabilizer bar because the screw holes no longer align. The car is not movable anymore; it's stopped and ended up in my garage.
Da ich auch die Hydrolager wechseln muss, wäre das ja die gleiche Arbeit --> Aggregatträger unten, Motor abgestützt, Lager tauschen, fertig. StWhat does that mean?
"I'm sure some of you have already gone through this. Can you encourage me? Are there any tips you can offer? Where are the potential pitfalls?"
Thank you for your help.
Translated on 15-08-2026, 14:15.
hansihanson
dieselschrauber likes this.
Post16-08-2026, 7:17    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
Edit: Problem solved, it was very easy to just unscrew it!
Translated on 16-08-2026, 7:18.
Karma: +1354 / -0   Thank you, like it!
Post16-08-2026, 15:48    Subject: VW Passat Oil Pan Replacement: Lower Engine Mount Quote
The stabilizer can always be solved if both coil springs are equally pre-tensioned or not pre-tensioned at all.
Otherwise, you're lucky. Do not loosen or tighten the holding screws of the unit carrier if the vehicle is only jacked up. It must be on its wheels due to the torque requirements and subsequent rotational angle. Lower the vehicle only when supporting the engine from above, but do not use the air conditioning compressor as a support point. It is not a suitable support. Loosening (but not removing) the holding screws from the front may be possible depending on the model. The holding screws are stretch bolts and must be replaced after use.
Translated on 16-08-2026, 15:50.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Remote Window Control: Lower Electric Windows On-Board Diagnostics (OBD)
No new posts Tie Rod Replacement Passat 35i Transmission, Chassis, Body & Interior
No new posts Replacing shock absorbers on a Passat 35i **Parts Requir... Transmission, Chassis, Body & Interior
No new posts Damaged Threaded Bushing: Repair on Engine Mount? Transmission, Chassis, Body & Interior
