TDI 1Z: Einspritzpumpe lösen um Einspritzbegin zu verstellen | Posts 16+
Go to page: Previous  1, 2
haggis.dhi
Post20-11-2003, 16:08    Subject: Quote
A few months ago, I also had the problem with the injection timing slowly changing... I then had the screw and the washer examined by the dealership... The screw was 12.4, but even then, the cam lobe was already slightly worn, so I had it re-ground. icon_evil.gif
But the best part was: I would have preferred to have it done by VAG, because I thought they would know more about it, otherwise I would have gone to ATU, because I'm already on familiar terms with them. After the repair, I also went back to ATU, talked a bit with the master mechanic, and it turned out that VAG had lent ATU the special milling cutter for the crankshaft, because VAG didn't have one icon_rolleyes.gif.
Translated on 28-09-2026, 21:06.
haehnlein
Post20-11-2003, 17:06    Subject: Quote
haggis.dhi wrote:
A few months ago, I also had the problem with the injection timing slowly changing... I then had the friendly mechanics examine the screw and the washer... Screw size 12.4, but even then, the shaft was already slightly rubbing against the crankshaft, so I had it re-ground... icon_evil.gif
Then, either the icon_twisted.gif KW stub was already corroded when the screw was changed, or the torque of the 12.9 screw was incorrect }.
____________
Kein Auto mehr!
Translated on 28-09-2026, 21:08.
No new posts Document Golf 1J1587, Transmission Console Mounting Not R... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Very early fuel injection start On-Board Diagnostics (OBD)
No new posts Timing Belt Replacement SDI Engine -AGP- Injection Start Diesel Engine Technology
No new posts Adjusting the power steering assist? Transmission, Chassis, Body & Interior
No new posts AFB Injector Timing: Adjustment Guide On-Board Diagnostics (OBD)
