OBD Scanner for Audi 80 B4 TDI 1Z (1992)
lohbie
Post06-10-2026, 10:48    Subject: OBD Scanner for Audi 80 B4 TDI 1Z (1992) Quote
Hello.
I own an Audi 80 B4 TDI and I'm looking for a mobile OBD device for troubleshooting.
The problem is, I only need it once, so it's not worth buying an expensive device.
Is there an app for that, or a simple device?
Lohbie.
Translated on 06-10-2026, 10:49.
Karma: +1354 / -0   Thank you, like it!
Post06-10-2026, 14:26    Subject: OBD Scanner for Audi 80 B4 TDI 1Z (1992) Quote
If it's absolutely unique, why bother with troubleshooting?
Otherwise: https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php.
Perhaps acquire a VCDS HEX+CAN USB or a HEX-COM (VAG-COM), all with a 2x2 adapter. The original VAG-COM is perfectly sufficient. If the hardware is not cloned, there is also support available; otherwise, the approval ratings decrease icon_wink.gif.
Translated on 06-10-2026, 14:28.
lohbie
dieselschrauber likes this.
Post06-10-2026, 19:51    Subject: OBD Scanner for Audi 80 B4 TDI 1Z (1992) Quote
Hello Herbert,
Basically, you're right.
Why unique? Because the car stays.
I'll think about it. 280 euros isn't a fortune, after all.
Lohbie.
Translated on 06-10-2026, 19:52.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 100 Wiring Diagram: AAT Engine, 12/1992 Diesel Engine Technology
No new posts Timing Belt Replacement: No Diagnostic Tool Needed? Diesel Engine Technology
No new posts Tachometer Installation: VW Passat 1.6TD 1992 Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
