I'm having a problem with my 2.5 TDI that's slowly driving me crazy. Here's what's happening:
The engine is smoking quite a bit, especially when it's fully warmed up. The smoke is white and has a very pungent smell of diesel. Also, when the engine is idling, you can feel a distinct "threshold" between 2500 and 3000 RPM; you almost have to floor the accelerator pedal for it to rev higher. However, once you overcome that threshold, it revs smoothly as if nothing happened. Furthermore, it's very noticeable that when the engine is really warm (above 85°C), it starts to jerk significantly, to the point where the engine mounts can't dampen the vibrations anymore, and it's clear that it's not running smoothly. There are no error codes stored.
Basically, I've done almost everything to the engine, meaning new camshafts including lifters and hydraulic tappets, the turbocharger has been rebuilt, all seals are new, the timing belt and water pump are new, the oil pump chain is new, the entire cooling system has been completely sealed, the head gasket is new, all injectors have new nozzles and were adjusted by Bosch, and much more; so it was quite a major project
I also correctly adjusted the VP44 using the VCDS basic setting 04. He gets enough air (the intercooler system was leaking, but that has been fixed), and he also gets enough fuel (previously, the VP44 was drawing in air, but that has also been fixed). He most likely still has enough compression (not yet measured, but he starts cold like a charm).
I suspect it might be related to the VP44. Has anyone else experienced something similar? Does anyone have any idea how to reliably determine the cause?
Otherwise, the injectors would normally be a consideration, but since they have new nozzles and were calibrated by Bosch, I find it hard to believe. I did become suspicious when I picked up the injectors and asked for a test report; the service advisor told me that the nozzles were adjusted using a manual testing device, and therefore no report was available. I thought there would be proper testing equipment for two-stage nozzle holders, but Bosch probably knows what they're doing (hopefully).
So, as I said, if anyone has any ideas or has even experienced the same problem before, please feel free to reach out, thank you
