CAN Bus Problem: Troubleshooting & Solutions
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post26-11-2026, 20:21    Subject: CAN Bus Problem: Troubleshooting & Solutions Quote
Hello Rainer,
Yesterday, I tried to read the diagnostic data from a 2007 Volkswagen Golf V, but nothing worked. I couldn't access the engine control unit at all, and the auto-scan function didn't start either.
Just now, I looked at the installation file, and I noticed that the text "Load drivers for older versions" is no longer present. This entry is gone, which is probably why the system loaded or installed the latest drivers for version 26.9.0.
That's why, in my subsequent tests, "CAN not ready" always appears.
What can I do now to change this?
Should I download and install an older version, and then install the latest version later?
I just tried version 24... but I stopped the process because the entry was also missing there, as described above.
Version 26.9.0 is installed on my laptop, but it's not working.
Could you access my laptop using TeamViewer to take a look at it, or could you send me a link via email so I can get the program working again?
Sure, I'd be happy to help. Please provide the text you would like me to translate from German to English.
HG
Michi.
Translated on 26-11-2026, 20:53.
Karma: +807 / -0   Thank you, like it!
Post26-11-2026, 20:43    Subject: CAN Bus Problem: Troubleshooting & Solutions Quote
Hello Michi,
If the message "CAN not ready" appears, it means the driver is working.
Otherwise, the interface would not be found and could not be queried for its CAN status. It's possible that the setup of the German version is different, but that's probably not related to your problem.
Probably an electrical contact problem or a faulty CAN transceiver in the interface. Did you create a ground loop?
Translated on 26-11-2026, 20:55.
amishorty
Post26-11-2026, 21:31    Subject: HEX-USB+CAN: Windows & Driver Update Quote
Hi Rainer,
Thank you for the tip about the massage. I'll try it again tomorrow. If it doesn't work, I'll get back to you here.
You're welcome.
HG
Michi.
Translated on 26-11-2026, 21:32.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts DPF Problem: 2.0 TDI BPW A4 Diesel Engine Technology
No new posts VAG-COM Issues: Audi A4 Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Problem? Diesel Engine Technology
