Fuel Injector Metering Unit Failure
martin119
Post21-11-2003, 14:39    Subject: Fuel Injector Metering Unit Failure Quote
Hello.
After several visits to the workshop and incorrect diagnoses, the problem has finally been identified: the quantity adjuster of the fuel injection pump is defective. Previously, it was only determined that the fuel injection volume was too low, which was causing a lack of power.
The workshop said that this part wasn't available separately; it could only be replaced with the entire fuel injection pump.
Does anyone know if something like this is available for individual purchase anywhere?
Is the exchange process very complicated?
If necessary, I thought about getting a used pump and just replacing the flow meter.
Martin.
Translated on 06-09-2026, 4:29.
Post21-11-2003, 16:05    Subject: Fuel Injector Metering Valve Repair Quote
Hello Martin,
martin119 wrote:
After several visits to the workshop and incorrect diagnoses, it's finally clear: the quantity adjuster of the fuel injection pump is defective. Previously, it was only determined that the fuel injection quantity was too low, which is why there is a lack of power.
Ah, so it's happening again: the workshop is clueless and is replacing the fuel injection pump just to be on the safe side...
Either the turnout can be correctly controlled, in which case the reported track position is correct, or it cannot.
If not, a fault entry with emergency mode will be triggered very quickly.
The displayed error message would be clear!
The diagnosis provided by the workshop should therefore be viewed with some skepticism.
If there is a problem with the control valve or high-pressure component, it could make it difficult for the workshop to diagnose the issue without removing the pump. I will not go into further details.
martin119 wrote:
The workshop said that this part wasn't available individually; it could only be replaced by the complete fuel injection pump
Okay.
You won't be able to fix it, otherwise you wouldn't be spending so much money at various workshops. I'm not aware of any workshop that is capable of replacing the quantity setting mechanism.
Reason: subsequent pump settings, which have been described numerous times in this forum.
Okay Martin, we're not going to get anywhere if you keep posting random hypotheses from various workshops in this forum.
It helps no one, not even you.
You either trust the workshop or you don't. We don't have a crystal ball here, and we can't provide a diagnosis without expertise and the ability to measure things on your end.
Therefore, I would like to conclude this topic.
Translated on 06-09-2026, 4:33.
hturborbo01
Post22-11-2003, 21:43    Subject: Fuel Injector Metering Unit Failure Quote
Hello Martin,
In my opinion, those from VAG don't have enough experience.
in order to assess something like that.
You should take it to a reputable diesel repair shop.
It would be best if these were also included with the pump testing rig.
...had another dynamometer.
I don't know where you live, but it's somewhere in the Essen/Oberhausen area.
I can really recommend a great workshop to you.
They specialize in diesel engines and automotive electrical systems.
They don't exchange them immediately, but can also be used as needed.
Also, it can also be used for repairs, even when it comes to the internal components of the pump.
hturbo01
Translated on 06-09-2026, 4:36.
diesel.gustav
Post22-11-2003, 21:47    Subject: Final Sentence: Tips & Examples Quote
Deleted upon request.
Translated on 06-09-2026, 4:37.
diesel.gustav
Post22-11-2003, 21:55    Subject: Fuel Injector Metering Unit Failure Quote
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Quantity adjuster afn Upload
No new posts Error Code N146: Quantity Setting Issue Diesel Engine Technology
This topic is locked, you cannot edit or reply. VP37 & Quantity Setting - Emergency Program Diesel Engine Technology
No new posts Fault quantity setting in the fault memory On-Board Diagnostics (OBD)
