jensr Guest
27-11-2003, 12:58 Subject: How smart is my engine control unit? (1.4 TDI-PD 2002) |
Hello everyone,
I'm not an expert in engine technology, but I'm trying my best to understand the concepts. I hope my contribution is posted in the right place!
I'm facing the decision of whether to have my 1.4 TDI-PD engine performance tuned or just leave it as it is.
Since this is a leased vehicle, I will not be making any modifications to the engine control unit (ECU).
Currently, I'm considering a '10Cent tuning' approach, which involves manipulating the injection duration by modifying the temperature sensor reading in the fuel line.
'I often read/hear the following statement about this:'
'If the injection timing is significantly delayed, the nozzle will still inject fuel while the piston has already moved much further down than in the original setting. In this case, the upper constricted edge of the combustion chamber located within the piston can be hit and melted by the burning injected fuel.'
My question is now:
As I understand it, the original engine mapping remains unchanged with a '10-cent' tuning.
There is a safety function or maximum value for the maximum injection duration/length. This should not be affected by tampering with the temperature sensor. Therefore, it's actually impossible to cause any damage through manipulation, even with 'extreme incorrect values' and continuous full load operation.
I would appreciate it if one of you could give me some feedback on this.
I want to form my own opinions and take a look behind the scenes of all those endless advertising promises.
Thank you & Best regards.
Jens.
Translated on 13-07-2026, 20:37.
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
27-11-2003, 13:13 Subject: How smart is my engine control unit? (1.4 TDI-PD 2002) |
1. As discussed in the technical article here, the 10Cent tuning method only applies to TDI engines with a distributor injection pump.
"Adjusting/modifying performance via temperature sensor is a bad idea; use the search function."
"The protective functions related to fuel injection volume do not engage because the engine control unit (ECU) does not receive any information about the actual fuel injection amount when using the VP-10 Cent tuning."
I don't feel like going through everything again and explaining why I still consider it acceptable even with reasonable settings. Please read the relevant article again.
-> Read first, then ask.
Translated on 13-07-2026, 20:40.
Profile PM WWW Garage |
jensr Guest
27-11-2003, 14:01 Subject: You're welcome! |
Hello Rainer,
Believe it or not, but your brief explanation helped me understand the technical articles enough that I now consider my question answered.
(this is not meant as an accusation!)
Protection function is deactivated.
2) Manipulating with a temperature sensor is nonsense/rubbish.
3) Tampering with the temperature sensor can definitely lead to direct damage.
It seems you often have problems with people who ask 'unqualified' questions without having read anything beforehand. I certainly don't belong to that group; I did read, and still didn't understand. Sorry. I was hoping for a more welcoming reception.
Thank you for your answers!
Best regards, Jens (who is definitely not getting chipped anymore...).
Sure, here's the translation:
'P.S. I couldn't find an article about PD tuning! Could you maybe try searching again?'
Translated on 13-07-2026, 20:42.
27-11-2003, 14:06 Subject: How smart is my engine control unit? (1.4 TDI-PD 2002) |
Hello Jens,
People often ask the same questions repeatedly because many don't bother to take a quick look at the search function or relevant articles.
Over time, one can become somewhat easily irritated about this kind of thing.
Regarding 10Cent PD Tuning:
/viewtopic.php?t=1524&highlight=pd+10cent+tuning
Translated on 13-07-2026, 20:44.
jensr Guest
27-11-2003, 14:20 Subject: Great! |
Hi Rainer, again,
na der Beitrag war ja mal genau richtig !
Thank you again!
Best regards, Jens.
Translated on 13-07-2026, 20:45.
