Hello Steffi H.
My Ibiza is from the Netherlands and has the QG1 engine.
How did you configure your Speedbuster P-box? Did you notice any changes in fuel consumption with a consistent driving style? What kind of performance gain did you achieve (perhaps with a dyno test)?
Best regards, Georg[/quote]
Hi Georg,
I had the box installed in my workshop. That was last December. Initially, it was set a bit too high, so on my first high-speed run...
At approximately 4,100 RPM, the emergency mode engaged. I then informed my workshop, and they reconfigured the system. They then reduced the power output slightly, and haven't had any problems since.
Unfortunately, I don't have Microsoft Excel installed on my computer (which is a pain). Unfortunately, I am unable to perform that task using Workssuite.
Purely based on feel, it's likely around 130-135 horsepower (my friend agrees).
In terms of consumption, everything has remained the same.
Originally, I wanted to get a dynamometer test to measure performance, but at around 53 euros, I decided to leave it at that.
allow.
Top speed without limiter (according to speedometer): approximately 210 km/h.
'with' ' ' ' ' : approximately 218.
Steffi H.
