aaz fuel injectors
addi007
Post10-12-2003, 11:44    Subject: aaz fuel injectors Quote
hello
with which opening pressure do the nozzles of an AAZ motor actually work?
Could one actually transplant TDI nozzles into an AAZ engine, even though they are different?
Post10-12-2003, 11:57    Subject: aaz fuel injectors Quote
Renovation is out of the question!!
The AAZ dowels are being extracted and are ...???.. Duesen.
The TDI Duesen are being plugged in (and with a so-called. (Successfully secured) and are Loch duesen (see Gremlin's avatar).
That really doesn't fit at all!!!
m
Uli S.
Post10-12-2003, 12:43    Subject: Re: aaz fuel injectors Quote
addi007 wrote:
What kind of opening pressure do the nozzles of an AAZ motor actually operate with?
The adjustment opening pressure is 155 bar. You can also adjust it higher or lower by unscrewing the nozzle holder and placing thicker or thinner adjustment plates under the spring. If you're unlucky, you already have 2 spring holders installed, which makes adjustment more complicated. But why bother? We, at Pöler, set a higher pressure so that even viscous engine oil can still partially atomize at a cold start of -10°C, but for diesel drivers, this only makes sense with boost pressures of 1.5 bar or higher. If you want to modify your car, take a look at the Stukov and Icecube forum: http://forum.piranha-net.de/
Could one actually also transplant TDI nozzles into an AAZ engine, even though they are different?[/
Martin has already said:
AAZ: Vortex Chamber Motor -> Nozzle
TDI: Direct injectors -> nozzle
These are 2 components that, in essence, have very little in common. Even if they fit mechanically, it would be utter nonsense.
Best regards, Uli
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
No new posts V6 TDI Injectors for AHU Engine Diesel Engine Technology
No new posts 110hp injectors in a 1Z 90hp engine?? Diesel Engine Technology
No new posts Injector Differences: AHH 90hp vs. AFN 110hp Diesel Engine Technology
No new posts Self-cleaning temperature for fuel injectors? Diesel Engine Technology
