Hubcaps for VW Golf 3 TDI Steel Rims
MONCHI
Post16-12-2003, 11:22    Subject: Hubcaps for VW Golf 3 TDI Steel Rims Quote
....I found some steel rims with winter tires from a Golf 3 TDI for my Ibiza TDI at a good price. I wanted to put normal hubcaps on the steel rims (the ones that are attached with a metal ring), but they don't fit because the center of the hubcaps rests on the rim. So, I need hubcaps that are slightly raised in the center, or can I not put any hubcaps on the steel rims at all? Here's a picture of the rim!
http://i21.ebayimg.com/02/i/01/09/9a/52_1.JPG
The rim has an offset of ET 38 and is also used on the Golf 3 VR6 and GTI. Could a different VW wheel cap (e.g., from a Golf 4, Passat, etc.) possibly fit on it?
I would be grateful for any help!
Monchi.
Translated on 04-10-2026, 7:50.
Post16-12-2003, 14:21    Subject: Hubcaps for VW Golf 3 TDI Steel Rims Quote
I don't want to mislead you, but as far as I know, if there are any covers at all, they're just small caps in the center of the rim that cover the wheel bolts and hub! I had something like that on my Polo once! You often see them on Polo 6N models.
Translated on 04-10-2026, 7:51.
Sir Tortsch
Post16-12-2003, 15:03    Subject: Hubcaps for VW Golf 3 TDI Steel Rims Quote
Yes, I think MatthiasTDI96 is right. As far as I know, there's a cover for those that only covers the screws up to that bulge.
Post18-12-2003, 12:03    Subject: Hubcaps for VW Golf 3 TDI Steel Rims Quote
"These rims only come with the original center caps designed for the Passat 35i. I also had those on my GTI. At least they properly cover the hub and bolts. However, you have to be careful, as 4-hole and 5-hole designs are not interchangeable."
They weren't particularly expensive in 1996, but of course, that doesn't necessarily mean anything for 2003 icon_sad.gif.
You could also try using aftermarket hubcaps. Most of them are designed to be quite large, so they tend to fit a wide range of vehicles. We bought some for our Polo 9N after the dealership wanted a whopping 86 euros (!) for a set of hubcaps, and even eBay was asking almost as much for used ones.
I found that the caps at the Gl*bus hardware store were well-made for a very reasonable price of €2.29. They have a metal ring, and the only thing I noticed was that the paint was a bit thin. But hey, for the money we saved, we can buy new ones every winter for years to come...
Translated on 04-10-2026, 7:53.
Post21-12-2003, 14:44    Subject: Hubcaps for VW Golf 3 TDI Steel Rims Quote
Here is the part number for the hubcaps for steel rims with a 5/100 bolt pattern: 3A0 601 149 B.
Approximately 12 euros per piece, net.
Translated on 04-10-2026, 7:54.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 15" Steel Rims with 312mm Brakes? Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
