Diagnostic adapter | Posts 16+
Go to page: Previous  1, 2
Andy
Post18-06-2002, 21:23    Subject: Diagnostic adapter Quote
Please provide the text you would like me to translate. I need the text to be able to translate it from German to English.
http://www.planetfall.com/~jeff/obdii/
Paule
Post19-06-2002, 13:19    Subject: Questions upon questions Quote
Thank you, Andy icon_smile.gif.
I just don't want to take the car to the workshop.
I'm losing track of things.
What actually happens if you disconnect the crankshaft position sensor (G-2icon_cool.gif from a perfectly functional TDI engine with a Z1 or AEY engine code, while the ignition is off?
Turn the ignition on, then try to start the engine (which, of course, won't start).
Turn the ignition off again, then reconnect G-28.
Would the engine start again now?
Would the engine only run in emergency mode?
Or, even if there was an error in the diagnosis, would it still function normally?
Greetings to you all.
Paule.
Michael II
Post19-06-2002, 13:44    Subject: Diagnostic adapter Quote
The engine would start and would not be in emergency mode.
The engine control unit would have an incorrect entry:
G28, no signal, intermittent.
Tschüss
Michael II
Paule
Post19-06-2002, 14:38    Subject: Time to get crafting again Quote
Thank you, Michael II icon_smile.gif.
So, are you saying that there's no need to expect any loss of performance? Is that correct?
icon_idea.gif Then I'll now remove the speed sensor (G28) again.
and I'll take them out of my Vento and swap them.
Then I'll be certain whether it's related to the G-28.
See you later.
Paule.
Paule
Post21-06-2002, 16:27    Subject: It's working a little bit Quote
Hey everyone.
I just finished this test, and it was quite a hassle getting that old, rusty speed sensor (G_28) out of the Vento.
The Caddy also won't start with the alternator from the Vento.
But the fuel pump from the Caddy works in the Vento icon_rolleyes.gif.
So, it's not the G-28!
Okay, then I'm left with only the option of going to the lion's den icon_mad.gif (VAG), having the immobilizer code re-entered, or does anyone else have another idea??? icon_idea.gif
Hi Paule,
Paule
Post28-06-2002, 20:58    Subject: step by step Quote
Hello everyone.
Worked at VAG. The code was re-entered, but nothing changed.
The security guard was actually friendlier than I expected.
He was even so kind that he gave me all the documents for checking the ESP. icon_smile.gif
Does anyone know if there are any more documents available?
How to measure the pins of the engine control unit (ECU).
Okay, so, what's the input and output in terms of Amps and Volts?
Thank you in advance.
Hi Paule,
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy 2.0 SDI: Starting Problems & Troubleshooting Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
No new posts A6 5-cylinder. TDI won't start Diesel Engine Technology
No new posts 3.0 TDI ASB: Won't Start - Troubleshooting Guide Diesel Engine Technology
