Here's just the difference compared to the EURO3 180PS model!
• Pistons made from a new, more heat-resistant alloy to compensate for...
higher thermal load.
• Modification of the piston bowl shape to optimize the combustion process.
• Compression ratio reduced to 18.5:1 by increasing the piston bowl volume.
• Piston/connecting rod with a trapezoidal head to compensate for the higher combustion pressure.
and to reduce the oscillating masses by approximately 10%.
• Crankcase with an additional ventilation duct on the front of the engine to reduce...
of the oil content in the engine ventilation system.
• Reduction of air entrainment in the engine oil through lateral baffles in the...
Crankcase.
• Crankcase ventilation system with a cyclone oil mist separator to reduce...
Oil content in the oil mist and blow-by gas.
• Radial piston distributor injection pump VP44S3 with 3 pistons for higher...
Injection pressures. At rated power, injection pressures of up to 1850 bar are achieved.
• Neu ist die Voreinspritzung über die Ansteuerung des Magnetventils. Sie sorgt in
Connection to the dual-nozzle holder assembly for reducing...
Popping or crackling sounds, especially when the engine is cold.
• Six-hole instead of five-hole injectors for improved fuel-air mixture preparation and reduced emissions.
• Turbocharger made from a more heat-resistant material, with an optimized turbine and...
Compressor wheel and improvements in the kinematics of the guide vane adjustment.
• Pre-catalyst located directly after the turbocharger.
• A larger oil-coolant heat exchanger compensates for the effects caused by the...
Increased performance leads to higher thermal stress on the engine oil.
• Fuel cooling using a fuel-coolant heat exchanger and...
Engine coolant-to-air heat exchanger integrated into the engine cooling circuit.
• EDC15 M engine control unit.
And those are just the changes that I am aware of. The EURO4 V6 TDI is even supposed to have 7-hole fuel injectors.
Manuel.
Translated on 26-10-2026, 2:21.
