Climatronic G3 TDI
ducmen9
Post04-02-2004, 15:32    Subject: Climatronic G3 TDI Quote
Hello, I want to install a Climatronic system in my G3 TDI. After studying the plans, I have a question. Can someone tell me where all the vacuum lines need to be connected? Specifically, I'm referring to the supply unit with the reservoir and the two-way valve. Everything is already connected on the control panel itself.
'I'm missing the vacuum supply unit... So, if anyone can sell me one, I would be very happy!'
Best regards, Tom.
Translated on 18-07-2026, 18:05.
Benno
Post05-02-2004, 15:02    Subject: Vacuum supply Quote
HI,
Which vacuum supply unit are you referring to?
The vacuum line is connected to the vacuum pump using a T-fitting. Additionally, there is a check valve in the line to prevent the vacuum reservoir from being emptied when the engine is turned off.
Is that enough?
Best regards, Benno.
Translated on 18-07-2026, 18:06.
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Log Climatronic Upload
No new posts T4 Climatronic: Climate Control System Transmission, Chassis, Body & Interior
No new posts Climatronic Error 214: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Climatronic Coding: How to Program Your Car On-Board Diagnostics (OBD)
