Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph
Holli
Post03-02-2004, 23:54    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Hello.
Could any of you perhaps give me a tip if I'm driving at a speed of around 110-120 km/h?
'When I accelerate quickly with full throttle, it briefly behaves as if I'm releasing the gas, but then it doesn't accelerate further and gets stuck at that speed. If I release the gas or accelerate gently, this behavior repeats until around 140 km/h, after which it drops off. However, I can accelerate quickly, even with full throttle, in the lower gears without any issues.'
Würde mich über ein paar Tips von euch freuen. DThank you!
Holger.
Translated on 28-08-2026, 9:00.
Markus H.
Post04-02-2004, 0:35    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
He who seeks shall find.
You should be able to find a lot of information about that by using the search function.
Most likely, it's a defective (and inexpensive) 'boost pressure limiting solenoid valve.'
Let's try swapping them out for now.
Translated on 28-08-2026, 9:01.
Post04-02-2004, 11:51    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Okay, and if you look at the error memory of the MSTG (Motor Steuergerät), you can narrow down the cause even further...
Translated on 28-08-2026, 9:02.
Lucas
Post04-02-2004, 12:24    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
It sounds like the diesel filter needs to be replaced. I can definitely understand the issue you're describing, as I've had a similar experience with the same type of car.
haehnlein
Post04-02-2004, 13:41    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Hi Holger,
Check the hoses on the magnetic valve for boost pressure limitation (-> replace all of them). In our Audi 80, one of those hoses was worn through, causing the same symptoms. It's also a good idea to replace the valve itself at the same time.
____________
Kein Auto mehr!
Post04-02-2004, 14:50    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Why doesn't anyone check the error memory? The reason for the limp-home mode is written in there... I just don't understand it. Are we back to aimlessly replacing parts again? icon_rolleyes.gif
Translated on 28-08-2026, 9:03.
haehnlein
Post04-02-2004, 16:37    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Rainer K. wrote:
Why doesn't anyone check the error memory? The reason for the limp mode is written in there... I just don't understand it. Are we back to aimlessly replacing parts again? icon_rolleyes.gif
Hi Rainer,
You are of course right icon_exclaim.gif. However, it seems like a diagnostic system is not available. A specific hose connected to the solenoid valve is very likely the culprit, as it was not installed very intelligently in the AUDI 80 and therefore rubs during operation (this problem, for example, does not exist in the Passat). I would check that first before getting too worried.
____________
Kein Auto mehr!
Translated on 28-08-2026, 9:04.
Markus H.
Post04-02-2004, 20:59    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Rainer, logically: of course, read the error memory.
But anyone who can't figure that out without asking in the forum... well, I don't know what to say.
However, Holli's description strongly suggests that the problem lies with the solenoid valve (or hose).
Translated on 28-08-2026, 9:05.
Post04-02-2004, 22:57    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Holli
Post05-02-2004, 19:47    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Hello.
I just wanted to let you know what the problem was that caused it not to start. I replaced two hoses, one of which went from a valve to the turbocharger, and since then, it's been running perfectly again.
I wanted to thank you all for the many helpful tips.
Holli.
Translated on 28-08-2026, 9:06.
Post05-02-2004, 20:19    Subject: Audi 80 TDI: Jerking/Shaking in 5th Gear Above 120 mph Quote
Holli wrote:
Hello.
I just wanted to let you know what the problem was that caused it not to start. I replaced two hoses, one of which went from a valve to the turbocharger, and since then it's been running perfectly again.
I wanted to thank you for all the tips you gave me.
OK, thank you for the clarification!
Translated on 28-08-2026, 9:07.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einbruch Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Vibrationen bei hohem Tempo Transmission, Chassis, Body & Interior
No new posts Wackelige Fahrt bei Tempo 70! Transmission, Chassis, Body & Interior
No new posts Steering Wheel Vibration Above 80 km/h? Transmission, Chassis, Body & Interior
