Solenoid valve (boost pressure) clicking
kossmann
2016 Audi Q3
Post06-02-2004, 20:51    Subject: Solenoid valve (boost pressure) clicking Quote
"Hey, is it normal for the wastegate solenoid valve (that small square box with the three pressure hoses) to click when you turn the ignition on, but don't start the engine?"
Audi 80 (B4), 1.9 TDI (1Z), manufactured in March 1994.
Avatar-Jan6K
Post06-02-2004, 21:03    Subject: Solenoid valve (boost pressure) clicking Quote
*sigh*
This has been asked/said a hundred times already... just search!
Yes, for some 1Z models, it's normal. For details: search!
Jan.
1Z5 CFHF / AHB H4D
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Frage zum Ladedruck Magnetventil beim 1Z Diesel Engine Technology
No new posts Relay 109 Clicking in VW Passat 35i On-Board Diagnostics (OBD)
No new posts ABS Relais klackert bei langsamer Fahrt Diesel Engine Technology
This topic is locked, you cannot edit or reply. VW Touareg: Clicking 3.0 V6 Kong Engine Noise? Diesel Engine Technology
