Hi dieselmartin.
Thank you for the response.
I don't just want a .xls file where everything is in one column, but rather a file where all the characters between two commas are written into a separate column, and the commas themselves are removed. So, all the data from the first column should be divided into 16 columns.
So far, I have only found that you need to replace the commas (,) with semicolons (
) for Excel to split the data into columns. However, some values are automatically reformatted as dates (the month is written in letters). If I set the format to "Standard," only numbers appear, but they are the wrong numbers.
I'm now looking for a way to open a modified .csv file without Excel interpreting the data in any way (e.g., as a date), so that it is displayed unchanged.
Thank you very much for your help.
Best regards, harix84.
