V6 TDI sporadisch im Notlauf,Werkstatt möchte Lader tauschen | Posts 32+
Go to page: Previous  1, 2, 3
mersente
Post10-02-2004, 23:40    Subject: Quote
Hello, if that doesn't work, try applying vacuum to the can and connecting it to the VTG (Valve Timing Gear). The membrane might be damaged, which isn't uncommon.
master_328
Post11-02-2004, 9:34    Subject: Quote
'The membrane was torn, a new pressure sensor has been installed, it cost €77 plus VAT... The car is running perfectly again!' You're very welcome!
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8V 2.0 TDI: Intermittent 5V, Limp Mode Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Passat: Intermittent Limp Mode Issue Diesel Engine Technology
No new posts AEL: Intermittent Limp Mode - Faulty Pressure Sensor? Diesel Engine Technology
No new posts VCDS/OBD2 Diagnostic Tool for Sale On-Board Diagnostics (OBD)
