I have a question about a non-diesel engine.
It's my 15-year-old Volkswagen Golf I Cabriolet with 172,000 kilometers (approximately 107,000 miles) on the odometer.
Recently, I heard some noises, and after a quick inspection, it was clear that they were coming from the power steering pump, which was completely empty of oil.
After refilling the oil, the noise was gone.
Unfortunately, I found the oil on the power steering unit again.
The rubber seal had two small cracks from which oil was leaking.
While removing the cuff, I encountered a significant amount of oil, approximately 0.2 liters.
Upon inquiry with VW, it was stated that the servo unit was defective
'This is not repairable and needs to be completely replaced; the material cost alone is 530 euros.'
Does anyone have any experience with this?
Is it okay to have oil inside the cuff?
Can a new one be installed, or will it break again after a short time?
Can the servo gear be repaired?
Are there no individual parts available for the gearbox from VW, or somewhere else?
Maybe someone here has an idea.
Faxes.
