Ruckeln beim AXR. Ich weiss nicht mehr weiter... | Posts 16+
Go to page: Previous  1, 2
Marco
Post11-02-2004, 0:02    Subject: Quote
Hello VipViper2000.
Here's the short version for this time of day.
The aforementioned solenoid valve controls the wastegate of the turbocharger.
Depending on the valve's duty cycle (the rapid switching between atmospheric and vacuum pressure), the actuator adjusts the guide vanes of the VTG turbocharger to increase or decrease boost pressure. When the exhaust system is installed, the turbocharger has more difficulty reaching the desired boost pressure for the specific operating condition. In response, the control unit increases the duty cycle of the solenoid valve until the boost pressure is correct.
Translated on 23-10-2026, 18:46.
VipViper2000
Post11-02-2004, 8:11    Subject: Quote
Good morning!
Okay, that's not so easy! So, I'm going to go there today and have them check the exhaust gas recirculation system thoroughly. What I still don't know is: What does the abbreviation 'VTG' mean?
VipViper2000
Translated on 23-10-2026, 18:47.
Avatar-Jan6K
Post11-02-2004, 8:14    Subject: Quote
HI,
VTG = Variable Turbine Geometry.
There's also a technical article about it in this forum that explains the function in detail.
Jan.
1Z5 CFHF / AHB H4D
Translated on 23-10-2026, 18:48.
VipViper2000
Post11-02-2004, 16:57    Subject: Quote
So, I just spoke with the mechanic, and he said he wants to have his 'diesel specialist,' who also installed the new injectors for me, take another look at my car next Tuesday. However, he can't just replace the dual-mass flywheel without a proper diagnosis, which is what I suspected.
Well, let's see how it goes.
VipViper2000
Translated on 23-10-2026, 18:49.
mersente
Post11-02-2004, 20:37    Subject: Quote
Hi, could you please have the friendly technician check the idle speed control again?
I suspect that it is still not in good condition.
If that's the case, I suspect a faulty dual-mass flywheel.
There is also the possibility that the channels within the engine block have narrowed due to the EGR system.
However, the ZMS is more likely.
Also, please tell the friendly person to check the HST (Service Manual); they're sure to find what they need there.
Translated on 23-10-2026, 18:50.
VipViper2000
Post12-02-2004, 0:04    Subject: Quote
Hi!
So, I told him about the exhaust gas recirculation system, and that's supposed to be checked on Tuesday. And the whole car should be checked again. As I said, let's see what happens.
The problem with the phrase 'I'm just guessing...' is that someone always has to be found to pay for it. If it really was due to the ZMS (presumably a component or system), then everything is fine. But if not, you have another problem. Well, I'll see what can be done. He is trying, after all; he already installed the new engine control unit for me completely free of charge.
VipViper2000
Translated on 23-10-2026, 18:51.
VipViper2000
Post12-02-2004, 13:52    Subject: Quote
Hi everyone!
In addition to the problem with the jerking, yesterday he did something for the first time: I start in first gear, release the clutch, and then I hear a short squealing/whistling sound. He does the same thing when I'm in first or second gear and I take my foot off the gas; then I hear a faint squealing/whistling. Please don't tell me it could be the turbo, because I'll have a panic attack.
Okay, so I just opened the hood and took a look. While doing that, I noticed that a semicircular plastic part had apparently fallen off and was just lying in the engine compartment. I have no idea where it goes. Here's a picture of what's on it:
>PA6 GF10 M20<
Maybe someone among you can make sense of this. Above this number, there's something smaller: VW (The VW logo) 06 1311 / 088(I'm not sure about this part, it's hard to read) 103 165
VipViper2000
Translated on 23-10-2026, 18:53.
joegolf
Post12-02-2004, 18:06    Subject: Quote
VipViper2000 wrote:
Hi everyone!
>PA6 GF10 M20<
This is just a material designation (polyamide, 10% fiberglass, etc.).
Translated on 23-10-2026, 18:55.
VipViper2000
Post12-02-2004, 22:54    Subject: Quote
Ohh.. That's funny. Okay, fine. And what about the other number? But that doesn't really matter. They should do that on Tuesday.
VipViper2000
Translated on 23-10-2026, 18:56.
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OIL PRESSURE SENSOR: Mechanic Stumped - Scandal! Diesel Engine Technology
No new posts AXR T3: Jerky Acceleration - Troubleshooting Guide Diesel Engine Technology
No new posts Corroded VTG rod, don't know what to do next. Diesel Engine Technology
No new posts TDI Problems? Get Help Now! Diesel Engine Technology
