Bearing speed drop/whining noise on a 96kW Ibiza
timo832000
Post10-02-2004, 18:42    Subject: Bearing speed drop/whining noise on a 96kW Ibiza Quote
Hello, dear Diesel Mechanic Forum,
Recently, I noticed that in my 96kW PD TDI Ibiza, occasionally, when I rev the engine while it's idling up to about 2500 RPM, the engine speed drops slowly, and the engine makes a slight 'whining' noise. Of course, as is often the case with showroom effects, it didn't do that at my dealer's. Does anyone else experience this problem? Could it possibly be related to the LMM?
Oh yeah, the car has only 1400 kilometers on it.
I would appreciate any response.
Best regards.
Timo.
mersente
Post16-02-2004, 23:53    Subject: Bearing speed drop/whining noise on a 96kW Ibiza Quote
Hello, it's probably not related to the LMM (likely mass flow meter), as it only provides the MSG (likely mass flow sensor) with the actual air mass. When you release the accelerator pedal, the engine control unit (ECU) is informed that no power is required, so the fuel injection amount is reduced and the idle speed is targeted.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD tuning for 96kW TDI engines Diesel Engine Technology
This topic is locked, you cannot edit or reply. Differenzdruck Partikelfilter und etwas träger Motor Diesel Engine Technology
No new posts OBD tuning for the Ibiza ASZ Diesel Engine Technology
No new posts G62 at the ASZ in the Seat Ibiza Diesel Engine Technology
