Is torque measurement possible? Any experiences?
carstenAFN
Post17-02-2004, 20:43    Subject: Is torque measurement possible? Any experiences? Quote
Can diagnostic tools also be used to measure a torque value, or to derive it from other measured values?
I once saw a sample file somewhere that had a column labeled "Torque"...
Carsten.
Translated on 09-07-2026, 9:09.
Post18-02-2004, 13:52    Subject: Is torque measurement possible? Any experiences? Quote
Some motor starting generators (MSTGs) display "estimated" torque values within a measurement block.
Translated on 09-07-2026, 9:10.
Post18-02-2004, 18:18    Subject: Is torque measurement possible? Any experiences? Quote
Rainer K. wrote:
manche MSTG zeigen in einem Meßwertblock 'geschätzte' Drehmomentwerte an.
But only PD motors icon_exclaim.gif icon_question.gif.
That would be completely new to me when it comes to VPs.
Post18-02-2004, 19:07    Subject: Is torque measurement possible? Any experiences? Quote
It's possible to check that at the ASZ, ULF!!!! The Polo is arriving tomorrow, so you can take a look at it then. But it's calculating the values quite accurately...at least, mine is.
Gremlin
Post19-02-2004, 5:53    Subject: Is torque measurement possible? Any experiences? Quote
It displays the calculated internal motor torque.
You need to subtract all frictional losses and auxiliary drives from that value. As a very rough guideline, the torque reading at idle can be used.
Then the displayed values are more or less correct.
CU Gremlin.
Translated on 09-07-2026, 9:11.
Tobaran
Post20-02-2004, 0:32    Subject: Is torque measurement possible? Any experiences? Quote
I once used VAG-Com for that.
Manually query the measured values in the engine control unit... in my case, it's point 20, and the value is called 'Torque' or something similar (the second value from the left).
And since I know the factory specifications for my engine, the torque value that is calculated here is roughly correct, but only if you do what Gremlin already described.
My engine already shows 28 Nm of torque at idle. That value is then subtracted, and you end up with a value that's approximately what you should expect if the engine is in good condition.
A test drive (ideally with a passenger who can observe the readings) will then reveal what's actually happening when you accelerate.
However, these are not really real values. They are theoretical, calculated values, but they can be reasonably accurate and at least provide some indication of whether there is something wrong with the engine.
Translated on 09-07-2026, 9:12.
Post20-02-2004, 0:52    Subject: Is torque measurement possible? Any experiences? Quote
"Oh really...? Well, it's probably logical that these are calculated values, or do you think they actually install a torque meter on the crankshaft in every car?"
Yes, I understand what Gremlin is saying, and I unfortunately didn't think of that. I'm being silly. I'll look into it further and then check its plausibility.
Translated on 09-07-2026, 9:14.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
No new posts Torque AJM 6-G Diesel Engine Technology
No new posts Torque Diesel Engine Technology
No new posts Axle Nut Torque: Specs & Installation Guide Transmission, Chassis, Body & Interior
