@ Thomas
I'm sure I didn't misunderstand you.
Higher pressure than in the standard trim: this can only be achieved with increased pressure from the mechanical system.
"So, the PD (Pumpe-Düse) problems likely only stem from the higher injection pressure specified by Ulf. However, I don't believe it's possible to achieve 2500 bar; that's 25% above the maximum pressure. And if VW had a trick to permanently maintain such high pressure, they would definitely be using it."
@roger
Yes, it's a really great company!
Seriously, I was thinking about a high-performance camshaft for the PD (pump injector) units. I hadn't thought about the valves. I was imagining something like a huge cam lobe that would push on the PD unit for over 300 degrees... (please don't take that seriously).
Translated on 10-08-2026, 3:38.
