Welche Modelle sind PDs | Posts 16+
Go to page: Previous  1, 2
Gremlin
Post09-03-2004, 21:29    Subject: Quote
Well, I would definitely slap a TDI on that right away.
or even better, SDI.
'Cu Gremlin'
Translated on 01-10-2026, 9:13.
Post09-03-2004, 21:33    Subject: Quote
Gremlin wrote:
Well, I would definitely put a TDI on that right away.
or even better, SDI
Hi Ralf,
It depends; when it gets warmer, it's easier to remove the lettering from the metal sheet.
icon_idea.gif SDI would also be quite good...
Gremlin
Post09-03-2004, 21:37    Subject: Quote
Okay, my 'old-grandpa-box'(tm) also had a 1.6D badge (which would have been the slowest engine option). Interestingly, it seems that BMW drivers pay attention to things like that, because when it still said '2.0i' on the back, I was bothered much less often when leaving the town... yeah, it's all in the mind icon_wink.gif.
btw: you must have a hairdryer, right?
'Cu Gremlin'
Translated on 01-10-2026, 9:15.
MONCHI
Post10-03-2004, 9:46    Subject: Quote
...and then there's the most powerful of the 1.9 TDI engines!
...installed in the Ibiza Cupra.
...it also has 3 red letters!!
...for those who are interested, it has 118 kW and 160 hp, and the engine code is 'BPX'.
http://carconfigurator.seat.de/images/fzg/2004/ibiza/fahrzeug/19TDI118kW.jpg
...now configurable at www.seat.de!
...as the advertisement says... icon_lol.gif ...typical Ibiza... } ...no half measures!! }
Monchi.
Translated on 01-10-2026, 9:16.
Post10-03-2004, 12:19    Subject: Quote
If you mean a loader by that: yes icon_lol.gif.
But one of the instruments never quite fits with the fake engine badges: the 260 speedometer for the SDI, or the 5000 RPM tachometer for the gasoline engine icon_cry.gif.
Translated on 01-10-2026, 9:17.
Post10-03-2004, 12:39    Subject: Quote
MONCHI wrote:
...and then there's the strongest of the 1.9 TDI engines!!
...as the advertisement says... icon_lol.gif ...typically Ibiza...
...no compromises!!
For me, a "sporty car" with the typical Seat-style forced packaging and full equipment is only half a thing because the power-to-weight ratio becomes unnecessarily bad icon_evil.gif.
On the other hand, my Polo is definitely much more likely to be considered "not half a thing" icon_lol.gif.
The Ibiza, in my opinion, shouldn't be called a CUP-Racer, but something like COMIX, for COMfort-IXpress icon_twisted.gif, because it will still be fast (-> top speed) . . . icon_rolleyes.gif
Translated on 01-10-2026, 9:18.
Gremlin
Post10-03-2004, 13:24    Subject: Quote
CU Gremlin.
Translated on 01-10-2026, 9:20.
timo832000
Post10-03-2004, 13:43    Subject: Quote
@Gremlin: You're right.
P.S. I also got an SDI badge for my ASZ, maybe we should stick a silver question mark behind it icon_wink.gif.
Post10-03-2004, 17:11    Subject: Quote
@GremlinViewing profile: Gremlin:
the person behind doesn't see that
That's right, but he sees the cloud and might hear the tractor, so SDI simply fits better icon_wink.gif.
Translated on 01-10-2026, 9:21.
Avatar-Jan6K
Post10-03-2004, 19:11    Subject: Quote
Hi Ulf,
If you're referring to a loader, then yes.
He's talking about a regular hair dryer... you can use it from a distance to soften the adhesive on the letters, which makes it easier to remove them, even in winter.
I'll probably do that soon, but then I won't be doing anything else.
Jan.
1Z5 CFHF / AHB H4D
Translated on 01-10-2026, 9:22.
Post10-03-2004, 20:50    Subject: Quote
Jan6K wrote:
He means a regular hair dryer, the kind you use on your hair... you can use it from a distance to soften the adhesive on the letters, and it also works well to remove them in the winter.
Oops icon_redface.gif icon_rolleyes.gif, I deliberately overlooked the most obvious thing...
However, just above 0°C, you can't lower the letters fast enough because the metal sheet cools down too quickly... so I'm waiting until the "real" spring.
Translated on 01-10-2026, 9:23.
Gremlin
Post11-03-2004, 5:31    Subject: Quote
But just above 0°C, you can't make the letters appear as quickly as the metal cools down... so I'm waiting until the 'real' spring.
For that, there's the FÖN.
A failed attempt can be adjusted continuously from 50° to 700° and also solves this problem icon_wink.gif.
CU Gremlin.
Translated on 01-10-2026, 9:24.
Post11-03-2004, 13:01    Subject: Quote
... 700 degrees:
Well, I think ulf didn't want to permanently etch the letters into the paint, but just to remove them icon_biggrin.gif ...
He's right about letting it cool down; I once tried that myself when I had something glued inside. With a 1200W hairdryer, you can direct heat onto plastic inside for hours, let alone onto the cold metal exterior with its good heat conductivity. And with a more powerful hairdryer, he's getting closer to the problem I described earlier.
If the sun has pre-warmed the surface, it will definitely work much better. With my Golf III, it even worked without a hairdryer if you remove the adhesive residue with a little bit of gasoline.
Translated on 01-10-2026, 9:25.
wacken
Post11-03-2004, 21:55    Subject: Quote
no guarantee of accuracy:
V6 TDI:
Silver with 150 horsepower.
red i with 180 hp.
It should be the same for A4/A6 sizes.
No, on the Passat, the smaller one has a red 'i', while the larger one has everything in red.
Translated on 01-10-2026, 9:26.
WarLord
Post11-03-2004, 23:52    Subject: Quote
Are you sure? The V6 TDI engines are usually marked specifically on the tailgate.
Best regards, WarLord.
Translated on 01-10-2026, 9:27.
wacken
Post12-03-2004, 5:01    Subject: Quote
Yes.
No new posts Which PDEs are identical? Diesel Engine Technology
No new posts Which light bulbs are the right ones ??? Diesel Engine Technology
No new posts SFD Affected Vehicles: Brands & Models On-Board Diagnostics (OBD)
No new posts Best Spark Plugs: Value & Performance Diesel Engine Technology
