Kolben der VP37 fest ?!? | Posts 16+
Go to page: Previous  1, 2
m3nx
Post13-03-2004, 13:07    Subject: Quote
Hi!
Okay, no problem. I installed a new O-ring, reassembled it, installed it, primed it briefly (there was no diesel left in the pump), and after about 10 seconds, it started working perfectly again and wasn't leaking anymore. Then I adjusted the pump using VAG-COM, and it was done.
Translated on 05-10-2026, 13:03.
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Vintage mechanics, solid Diesel Engine Technology
This topic is locked, you cannot edit or reply. AHU-TDI AC Compressor Stuck Diesel Engine Technology
No new posts Timing Belt Pulley Fixed: Repair & Solution Diesel Engine Technology
No new posts Audi A4 brake problem - Please help! Transmission, Chassis, Body & Interior
