Ruki Guest
17-03-2004, 10:50 Subject: |
Hi everyone!
My engine temperature gauge almost always reaches 90° - the needle points straight up (except when it was -12°C, then it didn't). The oil temperature fluctuates between 75 and approximately 100° depending on the load.
Ruki
Translated on 05-09-2026, 19:59.
WarLord Guest
17-03-2004, 14:12 Subject: |
@Gremlin
Yes, generally. My new Passat has fixed maintenance intervals (as one of the last 3B models, manufactured in 07 or 08/00, with a 115 hp PD engine), and yet it still has an oil temperature sensor.
Best regards, WarLord.
Translated on 05-09-2026, 20:00.
17-03-2004, 14:43 Subject: |
@ War
Do you have MFA (Multi-Factor Authentication)? Then this is for you.
My 1Z (without MFA) has an oil filter flange with a double hole, a blind screw installed, but there's a cable sticking out of it!
I don't know (yet) where the other end of the possible oil temperature gauge reaches.
Translated on 05-09-2026, 20:01.
Profile PM Garage |
Arne Guest
17-03-2004, 17:29 Subject: |
Hi Jan,
My A6 AFN also came with an oil temperature gauge as standard equipment.
You probably know it, it's located at the bottom left [of something].
During longer trips with full load, I also regularly saw temperatures around 130 degrees.
leicht drüber (35 Grad Schatten). My name is Mich.
I think your values are okay.
arne
Translated on 05-09-2026, 20:02.
WarLord Guest
17-03-2004, 18:04 Subject: |
@dieselmartin
I have an MFA, but it doesn't have an oil temperature gauge (since it's a 3B model, which doesn't include that).
