krümmel Guest
17-03-2004, 18:09 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
Transmission code is GNY; engine type is ASZ (96 kW).
I need the gear ratios and axle drive ratios.
What is the maximum torque for which the transmission is suitable?
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Thank you.
Crumbs.
krümmel Guest
19-03-2004, 19:17 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
Does anyone here actually know anything about this? There must be some information available somewhere.
Crumbs.
Steffarn Profi-Schrauber
21-03-2004, 17:15 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
It's just a normal automatic transmission.
They should theoretically be able to reach up to 700nm. B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
Joined: 04/12/2002 Posts: 18091 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
21-03-2004, 21:56 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
Translating... |
[Translating...]  |
Profile PM WWW Garage |
Gremlin Guest
22-03-2004, 9:23 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
they should actually be able to reach up to 700nm, !
Okay, the planetary alignment might take a while.
'But clutches, brake bands, and definitely not the WK.'
Without electronic adjustment, nothing will work because the transmission would otherwise be subjected to too low torque levels, and the control pressures would not be raised sufficiently.
CU Gremlin.
krümmel Guest
22-03-2004, 18:22 Subject: Maximum torque, 5-speed Tiptronic, Golf IV? |
Translating... |
es ist doch ein normales automatik getriebe.
sollten ja eigentlich bis 700nm drin sein, !
jo. der planetensatz macht das vielleicht ne weile...
aber kupplungen, bremsbänder und die WK mit sicherheit nicht...
ohne elektronikanpassung läuft da eh nix, weil das getriebe sonst von zu niedrigen drehmomenten ausgeht und die steuerdr¨¹cke nicht gen¨¹gend angehoben werden.
CU Gremlin
...na sind dann denn wenigstens 370nm ohne Änderung an der Steuerung drin.
Wie sieht es aus mit den Übersetzungen, weiß da jemand weiter?
Danke und Gruß
Krümmel |
