Is the injection start time counted differently in PD?
Post23-03-2004, 21:49    Subject: Is the injection start time counted differently in PD? Quote
In the log of my engine, the start of injection (which is the start of fuel injection in PD engines, group 004, block 2) appears with a negative sign compared to the AFN and ALH engines. icon_eek.gif icon_question.gif
At 1900 rpm and 25% throttle, the reading is "-3.7". During the subsequent acceleration, the absolute value increases to "-21.7" at just under 4000 rpm.
Reading this from the perspective of the VP-Logs, the start of the boost is shifted later rather than earlier, with increasing load and speed. icon_question.gif icon_question.gif
Is this reverse counting method in the PD-Logs normal, or do I have a bug somewhere in the system?
PowerSound3L
Post24-03-2004, 7:26    Subject: Is the injection start time counted differently in PD? Quote
hi,
For me, it just makes sense.
The injection starts before the top dead center (TDC) and is negative.
greetings
PS: But maybe the performance is lacking there.
because your engine injects fuel after top dead center icon_eek.gif.
Post24-03-2004, 18:51    Subject: Is the injection start time counted differently in PD? Quote
PowerSound3L wrote:
PS: but maybe that's where the missing performance is.
Hmm, but being about 40° out of phase (20 degrees after top dead center instead of before) likely costs more than just 20 horsepower (if we're being generous -> 134 horsepower according to the DZR instead of the 154 that are theoretically possible with extreme positive variation in the air-standard cycle)?
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Issue with starting the spray gun, model VP37 Diesel Engine Technology
No new posts Injection Start Timing: Adjust with Diagnostic Tool? Diesel Engine Technology
No new posts Injection start cannot be adjusted on the 1Z Upload
No new posts Start of spray in VAG-COM - what is + and what - On-Board Diagnostics (OBD)
