Help with installing the front engine mount on a B4 TDI
palmstrollo
Post05-04-2004, 7:27    Subject: Help with installing the front engine mount on a B4 TDI Quote
After replacing the fuel injection pump along with all the belts (timing belt, V-belt, and ribbed belt), the following question arose regarding the rubber mount located on the front lower end plate:
Does the engine need to be lifted when attaching the semi-circular support plate? If not, what is the purpose of that part? icon_question.gif
Thank you and best regards.
Hermann.
Cabriodriver
Post05-04-2004, 8:19    Subject: Help with installing the front engine mount on a B4 TDI Quote
Do you mean the part in front of the belts on the tensioner? That's just the torque support for the motor! The engine doesn't need to be lifted for that.
palmstrollo
Post05-04-2004, 9:20    Subject: Help with installing the front engine mount on a B4 TDI Quote
'Thank you, that's exactly the part I was looking for.'
I only don't understand one thing icon_redface.gif. The engine should tilt to the right or left under load. How is that part in the front supposed to support it?
I had already understood this support as a kind of engine mount.
Hermann.
Cabriodriver
Post05-04-2004, 15:13    Subject: Help with installing the front engine mount on a B4 TDI Quote
Sorry, but I'm not entirely sure about that either. I'll try to find out more. As far as I know, based on the Audi workshop manual, it's a torque support. I had to remove that part recently when I replaced the ribbed belt and the tensioner pulley.
Torsten
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post05-04-2004, 18:00    Subject: Help with installing the front engine mount on a B4 TDI Quote
I would say that the bearing is there to prevent the engine from tilting too much forward and backward during load changes. The actual engine mounts are located on the left and right sides of the frame and are firmly connected to the engine. icon_eek.gif
B.Eng (FH) u. KFZ Meister
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Hopa Plug Installation Help Diesel Engine Technology
No new posts Engine mounts T4 Transmission, Chassis, Body & Interior
No new posts Engine mounts Diesel Engine Technology
No new posts Engine Mount AFN for Audi A4 Diesel Engine Technology
