Jussi Schneider Guest
06-07-2002, 21:55 Subject: SEO-Optimized Title Translation:
**"Best SEO Tools: Improve Your Rankings Now"** |
Sorry  , you have a variable loader. However, it is also electronically controlled.
Translated on 23-10-2026, 11:39.
Stefan . Guest
07-07-2002, 14:03 Subject: SEO-Optimized Title Translation:
Okay, so I installed an exhaust system from an S4 (twin-turbo gasoline engine) on my A4 V6 TDI Quattro.
It's compatible with KAT models and has a noticeably larger pipe diameter than the original system (connection diameter: 2*55mm instead of 2*50mm).
The ONLY change I could notice was that the sound coming from the exhaust pipe was a little bit duller, otherwise, nothing seemed to have changed.
Neither airflow nor power consumption, nor the noise level, or any other subjective or objective changes. Except, of course, for the appearance.
Even with the significantly larger exhaust system from the RS4 (connection diameter 2*60mm, intermediate pipe 80mm), there is no change. In fact, this exhaust system doesn't even produce any noticeable noise.
I think that if you keep the original manifolds and catalytic converters, you can't really go wrong.
 Stefan.
Translated on 23-10-2026, 11:40.
wuze60 Guest
07-07-2002, 16:45 Subject: Faster Rotation: How to Spin Quickly |
Okay, okay. If the exhaust system has less back pressure, then the turbocharger spins too fast, and it receives too much boost pressure? Is it not electronically controlled in your car anymore? (When the control unit opens, the exhaust gases bypass the turbocharger and go directly into the exhaust.) }
Na sicher wird der Ladedruck elektronisch geregelt ! VTG Loader.
The tuner, however, pointed out that the variable geometry turbocharger (VTG) also has limits to its adjustment range, and that exceeding these limits could lead to excessively high peak pressures.
I've already discussed all of this with Rainer.
I'm going to check the peak pressure again and then measure the set boost pressure.
I guess they should fit, though, since I've never had this problem before.
Problems occurred (emergency program).
Wuze.
Translated on 23-10-2026, 11:42.
wuze60 Guest
08-07-2002, 22:01 Subject: Hy Rainer! |
Hello Rainer,
I've been following the topic of sports air filters again recently.
There are a lot of opinions on that.
If you'd like to try out an open sport air filter, feel free to do so.
And compare it to your other measurements.
I would be very happy to offer you my open-source JR cone filter, or rather, to lend it to you.
Because if that were the case, I would just send it to you by mail.
I would like to have it back afterwards, though.
What do you think about it?
Or are you already fed up with air filters?
Best regards, Mario.
Translated on 23-10-2026, 11:44.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
09-07-2002, 9:27 Subject: Re: Rainer, here's the translation:
**Subject: Rainer, here's the translation:**
* **Re: Rainer, here's the translation:**
**Explanation:**
* **Re:** This is a common abbreviation for "Reply" in email subjects.
* **Rainer:** This is the name of the person being addressed.
* **here's the translation:** This is a brief and clear description of the content of the email.
**SEO Optimization:**
* The subject line includes the keyword "translation" at the beginning, which is likely to help it rank higher in search results.
* The subject line is also concise and easy to understand, which is important for SEO.
**Alternative Translations:**
Here are a few other possible translations, depending on the specific context:
* **Re: Rainer, translation attached**
* **Re: Rainer, translation below**
* **Re: Rainer, translation ready**
I hope this helps! |
wuze60 wrote: | If you feel like testing out an open sport air filter,
What do you think about it? |
Hi Mario,
Thank you for the offer, but at least in my A3, the air filter is not a performance-limiting component.
With a cone filter, you're more likely to have the problem of drawing in cold air. The A3 has a well-designed solution for this as standard: it has a duct that runs directly from the radiator grille to the airbox.
Translated on 23-10-2026, 11:47.
Profile PM WWW Garage |
wuze60 Guest
09-07-2002, 21:32 Subject: Re: Rainer, here's the translation:
**Explanation:**
If you feel like testing an open sport air filter.
Hi Mario,
Greetings, Rainer
You're very welcome!
'On my 4-cylinder engine, there's also a suction pipe running from the radiator all the way to the original air filter box. That's why I've put the original box back on with the original paper filter. Advantages: 1. Always cold air intake. 2. I believe it offers the best filtration performance by far. 3. It's much quieter than an open filter. Disadvantages: I haven't noticed any decrease in performance, which is often assumed.'
Okay, I'm in favor of paper filters, mainly because of their filtration performance and because they require no maintenance; you don't have to oil them.
Mario
Translated on 23-10-2026, 11:50.
