I heard that recoding measurement block 7 from 00001 to 00002 demonstrably improves airflow. My friend has an AFN engine and performed this modification using VAG-Com. The time in the airflow calculation improved from 6.3 seconds to 5.9 seconds! He performed several measurements to be absolutely sure. The question is, what exactly did he change with this setting?
