Documented clutch failures in 4-Motion TDI-PD engines (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post10-07-2002, 14:51    Subject: Documented clutch failures in 4-Motion TDI-PD engines Quote
Golf/Bora 1.9L; TDI-PD; 4-Motion.
Clutch damage, 4Motion, Pump-Nozzle.
Due to a faulty cable holder on the engine, vehicles with 4Motion drive may experience a significantly increased misalignment between the engine and transmission.
As a result, complaints about the clutch may arise.
Procedure:
Check if the cable holder attached to the motor has one or two cable slots. If the cable holder only has one mounting point, it must be replaced with a cable holder that has at least two mounting points.
Part number 06A 971 845 L needs to be replaced.
Tschüss
Michael II
Ratings - Documented clutch failures in 4-Motion TDI-PD engines
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku VW, Bordnetzmanagement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A4 8D, Leistungseinbruch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Buy V6 TDI 4Motion: Best Deals & Reviews Diesel Engine Technology
No new posts Polo Blue Motion - BMS Upload
No new posts ESP Problem Golf 4 ARL 4Motion On-Board Diagnostics (OBD)
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
