Golf 4: Location of Distance Sensor
Dan.jel
Post15-04-2004, 22:08    Subject: Golf 4: Location of Distance Sensor Quote
DRW transmission.
I can't seem to locate it; is it hidden underneath the starter motor?
Translated on 13-09-2026, 22:42.
Frank A.
2000 Volkswagen Golf
Post16-04-2004, 6:00    Subject: Golf 4: Location of Distance Sensor Quote
"It's also located on the differential, like with the other transmissions, but not from the top, but..."
from the rear, roughly horizontally between the splash guard and the transmission.
Best regards, Frank.
'00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe
Dan.jel
Post16-04-2004, 6:01    Subject: Golf 4: Location of Distance Sensor Quote
Well, that could be quite a tricky job...
Translated on 13-09-2026, 22:43.
Dan.jel
Post17-04-2004, 11:49    Subject: Golf 4: Location of Distance Sensor Quote
It was a bit fiddly (I didn't have a lift), but first, you need to pull the connector out from the top, then loosen the retaining screw from the bottom with a 9mm wrench, and after that, you can pull out the distance sensor.
Unfortunately, the guy in the parts department gave me a WSS for a different transmission, because, as I discovered, the 6-speed manual transmission uses contactless (probably inductive?) measurement. The part number for my transmission, which is the DRW transmission, is: 1J0 919 149A. He gave me a 1H0 919 149C. icon_rolleyes.gif
During the disassembly, I also noticed that the contacts were completely dirty and corroded. (The connector can also fill up with water from the top.)
First, it was thoroughly cleaned and the rust was carefully removed, but the speedometer still doesn't show any speed.
Given that the ambient temperature is always freezing and the fuel gauge frequently drops to zero for short periods when driving on curves or over bumps (please refuel 'Piiiiiiiiiep'), the combination instrument is probably faulty.
I won't know if the distance sensor is also defective until I replace the instrument cluster.
Translated on 13-09-2026, 22:44.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does this connector fit a Volkswagen Golf 4? On-Board Diagnostics (OBD)
No new posts Golf 3: Location of the pressure relief valve. Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. TDI Golf: 115 PS to 150 PS Upgrade Diesel Engine Technology
No new posts Golf 4 Speedometer: Current Speed Flips Up and Down Diesel Engine Technology
