A4 B5 und Besch... Bremsleistung bei extremer Nässe | Posts 16+
Go to page: Previous  1, 2
MikeF
Post11-03-2004, 7:48    Subject: Quote
@joergs!
Here's a possible translation:
'What does 'perhaps' mean here? THIS helps! The axis for the A4 is the same, and that's why the problem exists.'
If anyone needs pictures, please send me a private message with your email address.
Greetings.
Translated on 04-10-2026, 21:25.
joergs
Post11-03-2004, 7:55    Subject: Quote
@mikef
After reading your article, it's clear to me that it will be helpful. The 'maybe' was more of a rhetorical question.
Translated on 04-10-2026, 21:26.
MikeF
Post11-03-2004, 7:59    Subject: Quote
Okay, so it's about the large metal sheet, the splash guard on the swivel joint, and the rubber on the brake disc. I assume that these parts are identical to those used for the A4 (up to the 312 model), so I think they should fit. It's definitely worth trying if it could save your life icon_wink.gif.
The A6 probably looks different now, but if VW knows that this helps, they should adapt the parts to all four-wheel steering axles. That would certainly make sense. But I can imagine VW saying, 'Millions of Passats are on the road, the A6... we won't do anything for just a few.'
Greetings.
Translated on 04-10-2026, 21:27.
faz
Avatar-faz
1994 Audi 80
Post17-03-2004, 20:24    Subject: Quote
The same thing happened to a 1998 Audi A4 that belongs to our family.
Driving in the rain is hell. It's hard to get used to the stupid and dangerous braking behavior. Luckily, my B4 doesn't icon_cool.gif.
@MikeF
Can you provide a review once you've installed the Passat solution?
Regarding fit and performance in wet conditions.
Thank you in advance icon_smile.gif.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 04-10-2026, 21:28.
mersente
Post17-03-2004, 22:07    Subject: Quote
Hello, it's well-known with VW/Audi that the braking performance when wet is not good.
That's why we'll soon have the 'brake disc wiper.'
Every few seconds, the brake is applied briefly to release any moisture from the brake disc.
The control system is linked to the windshield wiper or rain sensor.
One should be excited to see what happens.
Translated on 04-10-2026, 21:29.
MikeF
Post18-03-2004, 7:11    Subject: Quote
Hello!
While the brake pad squeegee idea is nice, it doesn't address the root of the problem! It's an addition, yes, but just the squeegee? Well. I know this because if I had 'squeed' my brakes like that back then, meaning only applying the pads intermittently, it wouldn't have helped my Passat at all, because the contact would have been too heavily affected by water!
Translated on 04-10-2026, 21:30.
joegolf
Post18-03-2004, 18:22    Subject: Quote
Does anyone know if something like that is also available for the Golf 4? icon_evil.gif There's also the wet brake problem there.
Translated on 04-10-2026, 21:31.
Diesel-Kai
Post25-03-2004, 18:58    Subject: Quote
I had a similar problem with my Passat Variant (model 2003).
Although the small plastic spoilers under the front bumper were already installed from the factory.
I approached them in a friendly manner and, while being friendly, I strongly emphasized the risks associated with braking.
Initially, the plan was to use salt/sand on the tracks for winter conditions, but that's not happening.
They have now installed new brake discs and pads free of charge/under warranty (warranty valid until 06/2004), even though I have already driven 44,000 km.
I've only been able to test it 2-3 times so far, but it seems to have improved.
Otherwise, I'll be back at the police station!
Translated on 04-10-2026, 21:32.
joegolf
Post06-04-2004, 17:41    Subject: Quote
Here you can also find more information on this topic:
http://www.ttatwest.net/tips/brems2000.html
http://www.ttatwest.net/tips/ams32001.html
http://www.ttatwest.net/tips/adac21999.html
Translated on 04-10-2026, 21:33.
ekolaus
Post21-04-2004, 20:03    Subject: Quote
I work at the company that manufactures VW brake components. This was originally a standard feature.
Problem solved by replacing the brake pads with a new grade of material.
'They no longer experience this phenomenon. I'm not sure what all is available in the accessories and spare parts market...'
Marco
Post21-04-2004, 21:22    Subject: Quote
Hi ekolaus,
That means I buy new, original brake pads from Audi (and hope they aren't some old stock), and the problem is solved?
Translated on 04-10-2026, 21:34.
No new posts VW T5, 2.0 BiTDI, excessive oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Performance and Engine Power Transmission, Chassis, Body & Interior
No new posts Kia Rio: Excessive Soot Buildup - 1.4 CRDi Diesel Engine Technology
