R Gear Problem: Polo AKU Transmission Compatibility
physician
Post23-04-2004, 16:57    Subject: R Gear Problem: Polo AKU Transmission Compatibility Quote
My Polo, like almost all of them, has a problem with reverse gear. I don't know what's causing it icon_question.gif.
After almost a year and a half, there was an even more unpleasant noise yesterday than usual. Therefore, I am now looking for a replacement gearbox.
Unfortunately, I'm not sure about the exact name, but I thought it might be DED.
The question is: Which transmissions are compatible with my engine?
My transmission has:
- Rods
- Clutch with cable actuation.
Da mir persönlich das Getriebe auch zu kurz ist (wenigstens im fünften Gang), könnte natürlich auch ein anderes Getriebe in Frage kommen. Nur which?
I didn't want to convert it to either a cable-operated system or a hydraulic clutch.
I would really appreciate any help. A table with the GKB (German part number) and all the translations (including the axis) would be very interesting, as it's possible that gearboxes from Golf 2/3 models might also be compatible.
Translated on 09-10-2026, 8:12.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which Control Unit Fits? Find the Right ECU! On-Board Diagnostics (OBD)
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Relay failure, but which one? On-Board Diagnostics (OBD)
